What Do I Do With Rotting Deck Supports? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-30-2012, 08:55 AM   #16
Civil Engineer
Rewards Points: 4,764
You may want to take a step back and define your objective. If your goal is to reconstruct the deck in a code compliant manner, you likely have many issues to deal with, including how the ledger is attached to the house, size of joists and beams, posts etc. If you are interested in the narrow objective of fixing just the small rotten area, my recommendation would be to sister a joist against it. This will not address the larger issue of the condition of the deck, but will certainly adequately address the relatively minor issue you mentioned.
Old 06-30-2012, 09:32 AM   #17
Pro
JetSwet's Avatar
Rewards Points: 502
It doest look like the joist goes inside the home, just attached to the ledger so replacing that 2x10 should be easy by taking the joist hangers off prying the joist out, removing nails on floor planks and installing new joist.
JetSwet is offline   Reply With Quote
Old 06-30-2012, 02:00 PM   #18
robertcdf's Avatar
We tear down decks that look like that all the time, the frame is rotted beyond repair, replace the entire deck. This time use materials that won't fail at a later date and you won't have to worry about it again. PT lumber is an ok product and will kind of suit your needs, certainly better than what you have. Steel is the best option because you gain so many more advantages.
robertcdf is offline   Reply With Quote
Old 06-30-2012, 02:46 PM   #19
kwikfishron's Avatar
Rewards Points: 576
That steel wouldn't last two years near the Coast, galvanized or not.
kwikfishron is offline   Reply With Quote
Old 06-30-2012, 02:51 PM   #20
robertcdf's Avatar
Well we dont know where the OP is from do we? So it has a very good chance of being a viable option.
Old 06-30-2012, 02:53 PM   #21
Rewards Points: 576
My point exactly.
Old 06-30-2012, 02:57 PM   #22
robertcdf's Avatar
BTW you're wrong about 2 years. http://www.steelsmartdeck.com/LifeSpan.aspx
http://www.steelframing.org/PDF/architects/RP06-1.pdf
So your opinions are pointless since they can be refuted by REAL studies not just opinions.
Old 06-30-2012, 02:59 PM   #23
robertcdf's Avatar
In case some of you don't want to read through the entire thing... The SHORTEST life expectancy when exposed to air in NJ near the ocean is 369 years... A far cry from 2 years as some people feel.
Old 06-30-2012, 03:27 PM   #24
Rewards Points: 18
I am perfectly aware that the deck is nearing the end of its life and that the railing is not up to code. However, between the expense of replacing it, and having had the last contractor at the house do an awful job AND steal heirloom jewelry, I'm going to do what I can to make it last.
Sistering the joist and repainting seems like the best for me until I get the courage to try to hire someone again. Thank you.
green.willow is offline   Reply With Quote
Old 06-30-2012, 03:32 PM   #25
Rewards Points: 576
Here’s a study for you. A Simpson galvanized joist hanger can turn to dust in just a few years on the OR/WA Coast. My cats paw being the source of that study many hundreds of times.
I can’t speak about the East Coast but out West where the weather actually come in off the Ocean that steel you show is junk.
The only chance a steel deck joist would survive the Coastal Pac. NW is if all penetrations were pre-drilled and then the steel was then sent to the galvanizer to be dipped and the coating remained undisturbed during and after installation. Even then the joist certainly wouldn’t last the hundreds of years your link claims.
Old 06-30-2012, 04:06 PM   #26
robertcdf's Avatar
Take it up with the NAHB (national association of home builders) not a small organization. They are the ones who were part of the test. I would be interested to know which exact hardware failed and what else it was in contact with. Some of Simpson's stuff only has g60 applied to it, it's easy to get g185.
Old 06-30-2012, 05:19 PM   #27
robertcdf's Avatar
Hey Ron, I assume you use EXCLUSIVELY stainless steel correct? Just trying to get a good feel for where you are coming from.
Old 06-30-2012, 05:38 PM   #28
Rewards Points: 576
Within 10 miles of the Ocean I do.
True HD galvanized does hold up ok if the coating is never breached and you’re even just a few blocks off the Ocean.
Old 06-30-2012, 05:49 PM   #29
robertcdf's Avatar
Are you talking about zmax? I've never seen hangers in anything other than zmax or ss. Zmax is g185 and I can order joists in that same coating.
Old 06-30-2012, 06:49 PM   #30
Rewards Points: 576
Zmax is what the local yard (Pro build) stocks along with SS. A 2x6 Zmax hanger is about a buck, in SS it’s about $8.
The thing with the Oregon Coast anyway is that even with a Zmax hanger, if it’s on a front row house you “will” have to replace the them within 5 years. At the 5 year mark they will likely come apart in pieces.
Just a few blocks off the Ocean it may take 7-10 years to see the same level of corrosion.
A couple of miles in it will take even longer yet but you’ll likely still see some surface rust after the first year.
As we both know what works in one place can be a Train Wreck somewhere else.
Id be curios on what BuiltByMac's views are on steel deck joist in his area. Even though he’s about 80mi inland from my costal location his area is still almost as wet (minus the salt).
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 11:36 AM
Deck post supports?? Mandy204 Building & Construction 2 06-09-2010 11:00 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
