What To Do With Cut Off Pcs Of Stud - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-13-2009, 08:31 AM   #1
Rewards Points: 174
What to do with cut off pcs of stud
I have roughly 60 or so 14" to 16" pieces of 2x4's. They were left over from a job I am doing in my basement. Can I use these pcs as top and bottom plates for walls? I was thinking that I could line them up, drill them into the floor/ceiling and then cut studs to size. I then thought about the integrity of a wall created that way and did not think that it would be stable.
If I cant use them for what I mentioned above then should I just throw them out? I would hate to waste so much wood.
Leoskee is offline   Reply With Quote
Old 08-13-2009, 08:39 AM   #2
General Contractor
You can use them for fire blocking, general blocking, cripples, firewood (if untreated), or for wood working projects.
ARI001 is offline   Reply With Quote
Old 08-13-2009, 08:40 AM   #3
the Musigician
DangerMouse's Avatar
you could always send them to me!
i'll find a good use for them!
DM
Old 08-13-2009, 08:42 AM   #4
Rewards Points: 174
Thats right! I completely forget about that. I was going to cut sheet rock pieces for the fire stops, like the building inspector told me I could do, but I can use the 2x4 pieces instead.
You just solved my dilema.
Thanks.
Old 08-13-2009, 08:58 AM   #5
I save scrap wood for fireblocking
Smaller pieces are burned in the fireplace
I don't have a ton of scrap
Since I'm finishing up my project I'll be burning off a lot this winter
Don't burn PT - very bad
Old 08-13-2009, 03:05 PM   #6
Rewards Points: 1,016
Two of my often goto items:
1) scrap wood pile of project left-overs
2) screw and bolt bucket of project left-overs
Old 08-13-2009, 05:41 PM   #7
Rewards Points: 5,336
I'd use the wood scraps to make fertility gods.
Ron
Old 08-13-2009, 05:44 PM   #8
I also keep a few by my hot tub to scare off raccoons, possums & skunks (very carefully)
Old 08-13-2009, 07:25 PM   #9
Rewards Points: 174
Fire blocking is enough for now. I'll take some of the suggestions and use them during another project. lol
Old 08-13-2009, 08:09 PM   #10
I guess you make them into shims or wedges. . .
Just don't collect so much stuff that you hate to waste so that you become like these guys
http://en.wikipedia.org/wiki/Collyer_brothers
I have a customer like that and I know two or three more families like that.
Old 08-13-2009, 08:12 PM   #11
Rewards Points: 264
There are some good places to put some shorts like that. In the corners at the bottom for the base trim to attach to-if you don't put in a little block the top nail does not have a good place to sink, unless you go for an extreme angle. Same with crown-it is good to have some backing for the nails. Also, backing for things like paper towel holders, toilet paper holders, places for handrails to attach.
And fire blocking : )
7echo is offline   Reply With Quote
Is it safe to remove this stud? lofar Remodeling 4 06-16-2009 11:22 PM
Plasma TV Mount problem - one of the 4 screws cannot hit a stud..... wasserkool Home Theater 4 01-05-2009 08:24 PM
Please, help with sheathing and stud placement Mrmusic Building & Construction 2 09-10-2008 04:52 PM
drywalling a wall with one stud not level? yummy mummy Building & Construction 5 12-21-2007 03:22 PM
How to butt wood stud wall to steel stud wall? Yorkergizer Building & Construction 3 12-01-2007 12:28 AM
