What DIY Garage Wall Texture?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-25-2009, 02:21 PM   #1
I'm in the process of finishing the walls in my garage. Is there a simple DIY way of adding texture? I don't don't have access to a texture rig, so what other options are there, skip trowel? Should I just add sand to the paint?
mopowers is offline   Reply With Quote
Old 08-25-2009, 02:34 PM   #2
Registered User
Rewards Points: 5,466
http://www.lowes.com/lowes/lkn?actio...242&lpage=none
Mix some texture compound with water, roll it on.
Or you can skim coat or skip trowel. Or a light knock-down after the roller. Or a round brush for any, be creative: http://www.drywallschool.com/textures.htm
Be safe, G
Old 08-25-2009, 06:53 PM   #3
Extreme DIY'r Adk's, NY
Rewards Points: 272
The Valspar Sand Texture paint the Lowes carries works quite well... especially if you like spider webs and cob webs forming quickly in your garage.
crecore is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 04:48 PM
Glueing Drywall to a Garage Block Wall PaliBob Drywall & Plaster 17 02-18-2009 05:12 AM
Smoothing out skip troweled wall texture wem Remodeling 2 03-03-2008 11:57 AM
Help Repair Garage Wall - Advice RandomJustice Building & Construction 8 07-28-2007 10:02 PM
Unique Wall Texture dcarlton General DIY Discussions 1 07-28-2007 09:27 PM
