Old 09-29-2012, 09:00 AM   #1
What is this crossbracing on my floor joists?
Just wondering what purpose this serves (see attached photo). It's about 7' from the wall only on one side of the house.
huesmann is offline   Reply With Quote
Old 09-29-2012, 09:48 AM   #2
Check out this website, it pretty much explains all you need to know about cross bracing.
http://www.homeadditionplus.com/fram...oor_Joists.htm
Ed911 is offline   Reply With Quote
Old 09-29-2012, 11:38 AM   #3
AHH, SPANS!!!
If needed now a days we add blocking mid span of the floor joists instead of the cross type bracing. It keeps the joists from twisting and moving over time.
hand drive is offline   Reply With Quote
Old 09-29-2012, 12:46 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
x bracing adds much more strength to the floor as compared to blocking. also x bracing completely block off the joist spacing in case plumbing or electrical needs to be run.. no drillinng or notching required
woodworkbykirk is offline   Reply With Quote
Old 09-29-2012, 06:31 PM   #5
Moderator
Only if a 1x4 or ceiling ties them together underneath.
Apples to apples, the solid blocking is 66% stiffer than x-bracing, add the 1x4 to the bottom= 167% less deflection; http://www.ewpa.com/Archive/2004/jun/Paper_278.pdf
Gary
Clothes taking longer to dry?
underfloor insulating with crossbracing Dhicock Building & Construction 3 10-18-2010 11:38 PM
Crossbracing on Floor Joists armyguns Building & Construction 2 10-29-2007 02:07 AM
