What Could I Do With My Inside Corners With Laminate Flooring On Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-23-2009, 08:29 AM   #1
yummy mummy's Avatar
Rewards Points: 1,016
What could I do with my inside corners with laminate flooring on wall?
Does anyone have any idea as to what I can do to finish off the inside corners when installing laminate flooring on wall?
I will miter the inside corners but I am certain they will not all look perfect.
Also with the outside corners is there a "rounded corner thingy"....... that I can use to finish it off?
yummy mummy is offline   Reply With Quote
Old 01-23-2009, 09:43 AM   #2
Are you running horizontal or vertical?
Chemist1961 is offline   Reply With Quote
Old 01-23-2009, 10:42 AM   #3
Horizontal
Old 01-23-2009, 10:54 AM   #4
the Musigician
DangerMouse's Avatar
perhaps some fancy quarter round?
DM
Old 01-23-2009, 10:57 AM   #5
the Musigician
oh, and outside edges, i usually rip off my own "L" moulding....
DM
Old 01-23-2009, 11:23 AM   #6
K&B Remodeler/Tile Guy
angus242's Avatar
Yes, there is a "rounded corner thingy". It's call inside corner molding or sometimes just IC molding. Sorry for the bad pic but this is what the end/profile will look like:
Should be able to find it at any of the BIG stores and in different kind of finishes too.
Angus
My Albums
angus242 is offline   Reply With Quote
Old 01-23-2009, 11:20 PM   #7
Thanks for the pic angus..........
I have seen those mouldings in the big box stores before. I just would have to paint it with a colour similar to the flooring.
Laminate Flooring restomod69 Flooring 2 12-24-2008 08:56 AM
New Flooring Curved wall dmonkpa1 Flooring 1 10-20-2008 05:01 PM
underlayment for quickstep laminate flooring Pturner Flooring 5 05-30-2005 04:09 AM
