What Is The Correct Way To Open A Pad Foundation? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-05-2011, 12:29 PM   #1
What is the correct way to open a pad foundation?
I have a condo the building is 2 story with a pad foundation, Since the pad needs to be opened up to find the leaking pipe under it which belongs to another unit. What is the correct way for opening the concrete pad foundation? I don't believe it should be jack hammered by the contractor, I was told it should be cut. I'd like to confirm this. I was also told that jack hammering would ruin the structure. Is this true & how can I confirm that?
dbcooper is offline   Reply With Quote
Old 05-05-2011, 03:10 PM   #2
Rewards Points: 5,336
If the jack hammering of the slab ruins the structure, you should not be living in the building.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
AndyGump (05-05-2011)
Old 05-05-2011, 05:05 PM   #3
As long as the area of interest is known, the cleanest way would be to use a concrete saw and cut the outline first, then use a jackhammer (or sledge) and break out the cut section. Just straight jackhammering could lead to cracks in areas you did not intend. As far as ruining the structure, the person might be concerned that you have a tensioned concrete slab. If you do, it will take A LOT of investigating, planning and careful work, to not cause damage to the structure and/or workers, and will most certainly involve a structural engineer. It is not too common in single family dwellings, but for multi-unit buildings, it could be. I would find out before breaking ground.
If this is a water supply pipe, any chance it would be easier to abandon in place a reroute through walls/ceiling?
Good Luck!
FixitDragon is offline   Reply With Quote
Old 05-05-2011, 09:34 PM   #4
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
Good Luck!
Excellent question about the possibility of a tensioned slab
To the OP, look for embossed lettering in the garage, usually the floor, to see if anything tells of a post and/or pre-tensioned slab.
Andy.
AndyGump is offline   Reply With Quote
To open up the kitchen or not timbo59 Building & Construction 15 04-30-2010 02:17 PM
Foundation or Load Bearing Wall Issue? sheribaby Building & Construction 3 04-14-2010 06:07 PM
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 09:34 AM
Replacement concrete garage floor, dowelled into foundation? Niffumdutz Building & Construction 5 02-19-2010 09:31 PM
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 02:49 PM
