Old 03-15-2010, 12:19 AM   #1
What is a 'concrete sill' for a sliding patio door?
This is for a finished cutout for a sliding patio door. Some are saying, you need it, others are saying that you dont.
What is the concrete sill AND DO WE REALLY NEED ONE?
I can't find a picture or tutorial or anything online about this and asked at Home Depot and the lady helping we said she doesn't have a concrete sill. When I see pics of sliding patio doors on the ineternet, I dont see any concrete sills... so forgive me for asking.
We have a 2 story brick home from 1984. We have cold winters here.
Please help.
Thanks!
mikedavid00 is offline   Reply With Quote
Old 03-15-2010, 02:16 AM   #2
Contractor
Brickie's Avatar
A limestone sill works very well. The limestone sill is what the door is sitting on in the photo linked below:
http://www.weathergardwindows.com/bl...3/IMG_7845.jpg
Northwest Indiana Masonry
Brickie is offline   Reply With Quote
The Following User Says Thank You to Brickie For This Useful Post:
mikedavid00 (03-15-2010)
Old 03-15-2010, 09:24 AM   #3
Perfect! Do you know where I can get one or have any information on this?
I can't seem to find much information at all on concrete/stone sills and I dont think I've seen them at the home stores.
Old 03-15-2010, 10:04 AM   #4
call a brick supplier
The older I get the better I was
Old 03-15-2010, 10:23 AM   #5
Concrete & Masonry
A concrete sill is something you would form & cast in place, rather than buy already made. You could also use a piece of Limestone as Brickie stated, or lay brick soldiers or "row-locks" under the threshold. Normally in the field, I would match the same design as what your home has under the rest of the doors.
PS, you'll only find a concrete sill needed in a full masonry veneer home like yours.
jomama45 is offline   Reply With Quote
Old 03-15-2010, 05:08 PM   #6
Ok an update.
The guy that we want to do the work says he uses brick stones placed apart to lay the door on. I'm assuming he puts 2x8 over the stones?
Does that sound suspicious to anyone?
Old 03-15-2010, 06:46 PM   #7
Old School
Willie T's Avatar
Originally Posted by mikedavid00 View Post
Ok an update.
I would not do it this way. No wood involved. Wood will eventually rot from the water that may get trapped under the track. And the recessed concrete is necessary to do two things:
One, it will keep the track (and the water that collects in it if it is rained on) below the level of your inside floor.
Two. The recess should be the same depth (or a taste deeper to allow for leveling the track) as the vertical strip of metal that forms the rear of your track (usually around 1/2" to 3/4") This is so you will not have a strip of metal protruding above your finished floor. (That would be a 'tripper', and would make it very difficult to sweep things out the door.)
As Jomama said, I form and pour the sill with hydraulic cement.
Willie T
Old 03-15-2010, 06:52 PM   #8
Moderator
kwikfishron's Avatar
I don’t even get the question. A concrete sill is what you have when your setting a door on a slab. It’s either there or not. If not then it's wood. It’s not something you go to Lowes for.
kwikfishron is online now   Reply With Quote
Old 03-15-2010, 07:32 PM   #9
Concrete & Masonry
Or in this case, a new door opening in a full masonry veneer wall. From what I'm reading, this door was cut in where there was not a door beore, so some brick was removed in the wall to accomadate a door. If the door is installed in the wood framing (conventionally), something needs to be put in place to cover the tops of the newly exposed brick. IMO, woo is NOT the right answer, it won't hold up near as long as the veneer is intended to. Like I stated before, I'd finish the brick just like the other doors in the balance of the house.
Old 03-15-2010, 09:22 PM   #10
Moderator
Sounds good to me 45, we don’t have very much brick veneer retrofit in my area out West here.
There are only 2 things I strive for in any remodel such as this.
#1 It functions properly .
And
#1 It looks like it’s always been there.
Old 03-15-2010, 11:11 PM   #11
What is heavy molded concrete sill with heavy patio door supposed to lie on?
So basically the winterized sliding patio doors (so heavy I cannot even lift it with two people), is supposed to lie on top of a concrete sill (I'm guessing it's also very heavy?). So once stacked, what does the sill lay on top to bear the weight?
Floor joists and exterior brick?
That's how it seems to be done on this video:
http://www.youtube.com/watch?v=_bfQpR6wMP4
That's like the only how-to to I can find on this.. and even then they are using 2 pieces of 2x8's it looks like.. not concrete.. I spoke to the Home Depot contractors today and now even he is telling me something different.
Old 03-16-2010, 08:17 AM   #12
Moderator
How about a picture of your hole in the wall.
Old 03-16-2010, 08:53 AM   #13
Old School
Willie T's Avatar
If it is necessary to construct a sill of wood as you have just described, make certain that you lay a full, sealed covering membrane (like a shower pan), open only on the front (for the water to run off to the outside). And be sure to caulk down inside your screw holes as well as around the tops of the screws.
Willie T
Old 03-16-2010, 11:17 AM   #14
It's not a actual hole yet.
I've decided to do the job myself now as all the contractors I'm speaking to basically want $1000 or more for 1 days work to do a sloppy job where water is going to leak through.
I'm just going to do the whole thing myself and ask for help along the way..
sliding patio door header... sharp Remodeling 2 11-03-2009 04:50 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 02:54 PM
Door Sill Flashing Pondo13 Building & Construction 1 08-19-2009 07:15 AM
How to: Measure Patio Sliding doors SunGawd Building & Construction 6 06-09-2009 10:06 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
