What Is The Code For A Landing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-27-2012, 04:28 PM   #1
what is the code for a landing
how wide should a landing be for be for a set of stairs
wca5221426@att. is offline   Reply With Quote
Old 02-27-2012, 04:32 PM   #2
ct code
what is the code for a landing on second floor deck
Old 02-27-2012, 07:38 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
all landings must be as wide and long as the stair is wide. if its wider your good.. most areas the minimum allowable width for a stair is 34" between the inside faces of the handrail
woodworkbykirk is offline   Reply With Quote
Old 02-27-2012, 08:16 PM   #4
Registered User
Rewards Points: 526
Check with your local AHJ.
If in the States and under an "I" Code:
R311.7.5 Landings for stairways. There shall be a floor or landing at the top and bottom of each stairway. A flight of stairs shall not have a vertical rise larger than 12 feet (3658 mm) between floor levels or landings. The width of each landing shall not be less than the width of the stairway served. Every landing shall have a minimum dimension of 36 inches (914 mm) measured in the direction of travel.
Exception: A floor or landing is not required at the top of an interior flight of stairs, including stairs in an enclosed garage, provided a door does not swing over the stairs. From: http://publicecodes.citation.com/ico...011_par014.htm
R311.7.1 Width. Stairways shall not be less than 36 inches (914 mm) in clear width at all points above the permitted handrail height and below the required headroom height. Handrails shall not project more than 4.5 inches (114 mm) on either side of the stairway and the minimum clear width of the stairway at and below the handrail height, including treads and landings, shall not be less than 311/2 inches (787 mm) where a handrail is installed on one side and 27 inches (698 mm) where handrails are provided on both sides.
And: http://www.inspectapedia.com/interiors/Stair_Codes.htm
Gary
Automatic Closet Lights Sav505 Electrical 52 12-28-2012 07:24 AM
Plumb island sink and AAV code for Ajax jhakkim Plumbing 2 02-13-2012 11:07 PM
Please Help - Error Code's 31, 32 and 42 on Carrier 58MVB 100 kolo HVAC 15 01-28-2012 10:13 PM
Lighting proximity to outdoor hot tub - Code Question jeffinpickering Electrical 0 09-12-2011 01:43 PM
Bryant Plus 90 Code 31 ~kirkland~ HVAC 1 03-08-2011 06:14 PM
