What Is This Blue Stuff? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-23-2006, 04:34 PM   #1
What is this blue stuff?
I have a question, I can see some blue foam maybe 1/4" thick under our sill plate in the garage. Is this some type of house wrap(i'm only familiar with tyvek), and since it's under the sill plate should I assume it is around the whole house? The reason i'm asking is I was not aware that house wrap goes under the sill plate. Also the sill plate has a green tint to it, is this because it is pressure treated? Thank you!
mellody27 is offline   Reply With Quote
Old 01-23-2006, 04:52 PM   #2
2nd half
Yes the sill plate should be pressure treated and the blue foam you see is the sill insulation, which is normal to keep drafts out.
jmic is offline   Reply With Quote
Old 01-23-2006, 05:02 PM   #3
thanks
Redguard or Blue Seal? KUIPORNG Flooring 15 08-10-2009 01:39 PM
Thread tape vs. Blue glue GT4NE1 Plumbing 9 07-10-2007 10:22 PM
Is it normal to see green stuff on the supply pipes KUIPORNG Plumbing 2 06-30-2006 11:21 AM
Blue Board georgetax General DIY Discussions 7 11-11-2005 09:05 PM
