What Is The Best Way To Hang A Heavy Antique Wood Framed Mirror To A Glass Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-10-2012, 04:09 PM   #1
What is the best way to hang a heavy antique wood framed mirror to a glass wall
My wife and I have a wood framed antique mirror that is 23 X 51 inches and weighs approximately 50 lbs. We want to hang it in our formal dinning room on a solid glass one piece mirrored wall. Any suggestions on how to do this?
jimmcfarlane is offline   Reply With Quote
Old 10-11-2012, 01:09 AM   #2
Registered User
Rewards Points: 5,228
Welcome to the forums! I'll move you to a better forum for more answers.
Gary
Gary in WA is online now   Reply With Quote
Old 10-11-2012, 07:42 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,142
Obviously, the last thing you want to do is i drill any holes in the mirror'd wall....
Just courious.....why a mirror on a mirrored wall?
Besides that....they make these little stick on picture hangers.....can't rememer their name...but they have a little tab at the bottom that you pull that lets you remove it. Your going to want a bunch of them.
Next....you need to modify your frame. The standard picture framing wire is not going to work. If it was me, I would be getting a strip of stainless steel, say 18g, the width of the frame (minus a 1/4" at each end) and about 4" tall. Attach that to the back of the mirror towards the top with a couple of short counter sunk wood screws. This is going to be sort of a modified clevis rail.
Next....attach a bunch of those stick on hooks (at least 6 to 8 of them) evenly spaced on the wall where you want the mirror to hang. You want them spaced so they are inside the mirror frame....and in as straight a line as you can make it...the straight part is the most important.
The frame SS strip will then hook into and hang on those hooks.
One thing.....make sure you clean the glass real good before you apply those hooks....I would use glass cleaner and then follow up with rubbing alcohol....you want NO oil on that glass....
Nice thing about those hooks....they stick well....and you can take them off...if they leave any residue...easy to scrape off with a razor blade.
The reason for the metal strip is to distribute the load evenly across the hooks...
The Following User Says Thank You to ddawg16 For This Useful Post:
jimmcfarlane (10-11-2012)
Old 10-11-2012, 08:06 AM   #4
Rewards Points: 13,300
I think I'd be looking at suspending it from the ceiling from wires instead of directly on the glass.
Once the hole is drilled there's no going back if you what to remove the mirror, there's no repairing that hole.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
How to butt wood stud wall to steel stud wall? Yorkergizer Building & Construction 3 12-01-2007 01:28 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
