What Is The Best Way To Cut A Concrete Block Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-12-2012, 09:20 PM   #1
What is the Best Way to Cut a Concrete Block Wall?
I have a CMU (concrete block) wall to remove and want to do it easiest way. I did this once 35 years ago, and it was a mess - but it worked. I have looked at the water cooled circular saws, but they are big and cumbersome. I'd like to rent a diamond blade chain saw, but can not find one in my area.
I would like to know if anybody has ever used a Sawzall with a diamond or carbide blade to cut block or mortar. I realize it will be slower, but I have time. It will also be dustier, but I won't have the slurry mess to deal with either.
I have 2 headers to cut that are about 5' wide and one header about 3'wide.
I have two sections to cut that are about 5' wide and 2,5' tall.
And a section about 8' wide and 7.5" tall.
I am open to suggestions!
Thanks.
BeachBum2 is offline   Reply With Quote
Old 08-12-2012, 09:38 PM   #2
Rewards Points: 512
i was going to say chain saw, score with the an angle grinder with a diamond wheel and a sledge hammer?
princelake is offline   Reply With Quote
Old 08-12-2012, 09:49 PM   #3
Rewards Points: 13,250
An angle grinder will not cut deep enough.
Rent a Cut off saw with a diamond blade.
http://www.stihlusa.com/products/cut...iamond-wheels/
Have you checked the Home Depot rental desk for a chainsaw?
PS There is no easy, dust free way to do this job.
Old 08-12-2012, 10:04 PM   #4
I've used one of those, but don't want to wrestle with it.
Haven't checked Home Depot - good idea.
How about a Sawzall? Am I crazy to think about one of those?
Old 08-12-2012, 10:10 PM   #5
Not going to happen, A carbide blade might last a min. cutting concrete.
Old 08-12-2012, 10:16 PM   #6
Framing Contractor
Rewards Points: 112
A grinder can work if you have access to both sides. It is much slower, and still dusty though. Never heard of a sawzall doing that.
sixeightten is offline   Reply With Quote
Old 08-12-2012, 10:20 PM   #7
Diamond blade
I have cut a few blocks on limited resources. Diamond blades seem to be the only answer. Sawzall isn't going to cut it. For the amount of money you put in blades you would be better off buying a saw. I picked up a 7 1/4 diamond blade at a big box store for around 20-30 bucks a few years back. Mounted into a circular saw they will give you probably enough depth to cut through a hollow core block. Make multiple passes, making shallow cuts. Most concrete will break once scored. Not safely, but the same 7 1/4 blade can mount to most angle grinders too. If you do that you have been warned. They are unstable and you won't be using any guards. Regardless whatever diamond blade you use you will have a dust mess for sure. If you are concerned about dust put up some plastic to minimize the area dust travels. Maybe even a box fan in a window. I recently cut through brick veneer and left the interior wall intact prior to cutting. This cut back a lot of the dust the accumulated inside the house.
Lastly. When I cut that brick veneer I used a 12 saw. The depth of the cut was only about 3.5-4 inches. If you do get your hands on one take it slow. Those saws have a lot of power and a little twist and that saw will want to kick and jump back at you.
bassheadjohn is offline   Reply With Quote
Old 08-13-2012, 12:58 AM   #8
I have watched several videos on the internet where they were demonstrating the use of a water cooled chain saw. It worked great, but so far, I haven't found one I can rent. That's where I thought of the Sawzall - as I own one of them.
I've used a 12" circular saw one a brick wall once... not the best as it doesn't go deep enough to make a clean cut.
Old 08-13-2012, 08:24 AM   #9
Rewards Points: 3,130
I once had to remove a non-load-bearing CMU wall in the basement of a 1950's house I owned. Very strange situation - the wall had to be original because the bottom course was embedded in the concrete floor. But it ran parallel to the floor joists and obviously wasn't supporting anything.
I got it down quite easily without any kind of saw. All I used was a brick chisel and a driller's hammer. I had to break just one block to get it out. After that, with space to move, I rapped on the mortar joints a few times to loosen them and all the other blocks came out whole.
Old 08-13-2012, 01:24 PM   #10
That's a good point, although I have one small section that I do need to "cut" so it looks clean... the rest could fall if it would. In that area, a chainsaw would be the best, I think.
Old 08-13-2012, 04:21 PM   #11
Ok... I found a rental ICS 680GC chainsaw with diamond blade. Same unit as the videos on YouTube.
Has anyone any experience using one of these water cooled chain saws on cinder block? Any "tips" would be greatly appreciated!
Old 08-13-2012, 06:29 PM   #12
Rewards Points: 3,406
When you say "headers" do you mean lintels?
Canarywood1 is offline   Reply With Quote
Old 08-13-2012, 07:11 PM   #13
I guess you could call them lintels, although they are not solid filled blocks.
The 5' ones are above the windows.
The 3' one is above a door.
Each is one block deep.
Old 08-13-2012, 07:34 PM   #14
You are adding windows and a door to this wall? You need to cut the openings for above items?
You need to add the appropriate lintels after you make the holes.
Be careful, when you cut out the lower blocks, the single row of block that you intend to leave in place may choose not to cooperate with your plan.
Evstarr is offline   Reply With Quote
Old 08-13-2012, 07:53 PM   #15
Thanks very much.
I'm taking everything out and installing a steel I beam, then a 15' sliding door system. I'll take everything out, down to the foundation and then pour a new 2.5" sill. I thought it would be better to remove all the CMU (not leave 2.5") as the last 2.5" might not be as solid as I'd like. It's easy to frame and pour this 2.5".
I have one larger area to remove, between one of the 5' windows and the 3' door. That wall section is about 7.5' tall and 8-10' wide. I'n not sure how many cuts it will need to get out of there. It looks like these saw chains are good for 40-80' of cutting. There is a big difference between 40 & 80' though!
Replacing a garage door with Concrete block wall Domenick Building & Construction 5 06-12-2012 11:19 AM
attaching poly board on concrete block wall acuts1 Insulation 7 04-29-2012 11:47 AM
new concrete block wall Ken Mc Painting 1 11-17-2011 10:06 PM
Bathroom Remodel - Resurfacing Plaster over Concrete Block itcanadian Remodeling 2 05-30-2011 11:10 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
