What Is The Best Sump Pump? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-16-2010, 03:14 PM   #1
Rewards Points: 79
What is the best sump pump?
We've had water in our basement twice in the past 8 years. The exhaust hose came off the sump pump the first time and it burned out the motor. The second time the float did not turn on the pump, had to giggle it to make it run.
We are replacing the drywall (mold), and want to put in a reliable pump. What is the best kind to get? We want battery backup and also an alarm if the water get too high in the sump well.
What does everyone recommend?
papageek is offline   Reply With Quote
Old 12-17-2010, 06:06 AM   #2
Rewards Points: 4,454
we use zoeller 1/3rd cast iron submersibles,,, never a pedestal pump for a pro - that's a tip-off plumbers did the work,,, pumps sit in a 35gal sump - no 5gal bucket,,, mechanical float switch, not the floating ping pong ball,,, plumbing pro supply only, NOT an apron/vest store,,, discharge line is 1 1/2" sched 40 pvc, NOT mickey mouse flex hose,,, you also need an adapter 'tween pump & pipe,,, don't forget the ck valve - 10' head on the pipe - 2" pvc gravity discharge after the 10'
backup pump - im-n-s-h-fo, absolute BEST is zoeller's water powered,,, 12v pumps have limited discharge capacity & even marine batteries run down quickly falling behind in ability to discharge as water rises,,, pump alarms are only $18 but, if no one's around, the alarm notifies whom ? if you are home & the power goes out, you'll know it when you're lighting candles,,, while the $ difference is slightly higher, i'd ONLY have wtr-powered backup in OUR home,,, good luck !
Old 12-17-2010, 09:09 AM   #3
Rewards Points: 79
Thanks for the input
You said:
Of course I have no control over that. The hole / sump that the pump is in definately looks bigger than 5 gal, but not much.
I'll go to the local plumbing supply center to see if I can get this unit.
If it is a 5-gal sump, it should still work fine -- right?
Old 12-17-2010, 11:27 AM   #4
Rewards Points: 590
Seems like a water-powered backup only makes sense if you have city water.
operagost is offline   Reply With Quote
Old 12-17-2010, 05:10 PM   #5
Stairguy
Millertyme's Avatar
Rewards Points: 508
i agree with itsreallyconc. I have my Zoeller hooked up with a seperate backup pump with a deep cell marine battery. all pvc pipe with a check valve. It was on the pricey side but well worth it. I also put in a french drain.
Millertyme is offline   Reply With Quote
Old 12-17-2010, 07:08 PM   #6
5 gal sump IS not the right size as your pump will be on/off/on/off & burn out sooner,,, the condition is known as ' shortpumping ' & can often be traced to an ignorant h/o or stupid plumber altho h/o's have been known to be stupid, also
yes, if the power goes out & you're on a well, tough **** IF you have ONLY the wtr-power'd backup,,, then your bride can ask ' why didn't you also get a backup emergency 10kw auxiliary generator instead of the new ( insert toy here ) ? ? ? ? ? ? '
Old 07-26-2016, 08:49 AM   #7
Rewards Points: 2
Re: What is the best sump pump?
the best sump pump? so far cshincorporated pump still works for me
fankDan is offline   Reply With Quote
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 08:46 AM
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Sump Pump Electrical Problem loftezy Electrical 5 09-06-2009 07:14 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
