What Is Best Portable Way To Drill Holes Through 1/2" Steel? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-09-2012, 05:13 PM   #16
kwikfishron's Avatar
Rewards Points: 824
Originally Posted by peakcelln View Post
Sounds like hiring the local welder for $200(His quote when I called him) may be best.
Five bucks a hole sounds like a deal to me.
kwikfishron is online now   Reply With Quote
Old 10-09-2012, 05:15 PM   #17
An old Tradesmen
Rewards Points: 7,816
Well, my partner in all this has had alot of experience in structural Steel framing, drywall, ceiling grid, etc in commercial applications; but not much in plate steel. I was understanding this process to be alot easier then it now appears.
It is easy, when you have the templates to give to the fabricator to make the holes.
Old 10-09-2012, 05:20 PM   #18
Thats funny ddawg16, thats exactly what the welder suggested as something else I could do; but I'd have to buy one, and the bits, and I'd be over $200...But thanx. At least I know the guy knows what he is talking about and is honest.
peakcelln is offline   Reply With Quote
Old 10-09-2012, 05:39 PM   #19
We were originally going to use the fabricator and he wanted the anchor bolts 7" square, but they were too expensive. Then we were going to cut the steel ourselves, then have this welder put them all together and save about $600.We had allready poured the concrete and thought we could mark the holes on the plates and number them when the welder put them together so it didnt matter if the anchors were exactly right. But the guy selling the steel, didnt have the tube steel he said he had. So, being in a bit of a time crunch, we decided to go back and have the fabricator do them. He actually cut his price a bit and made them affordable(About $125/column). But now, the anchors were not 7" square, so thats why we thought we'd just drill them ourselves.
Quite the mess. Ya live, ya learn...
Old 10-09-2012, 05:50 PM   #20
Rewards Points: 2,212
hind sight is always 20/20.
At $5 per hole I'd hire the guy to drill em for you.
2nd best try to rent one of those portable drill press deals, they are slick seen em in use.
3rd is a 3/4" drill with 1/4,3/8/1/2/5/8 holes, even if you have to rent the drill. There are tricks to drilling square holes with a hand drill.
Use CD as a mirror and drill through center, you'll see when it is off square. Drill a test hole even in wood and you will see what I mean.
mae-ling is offline   Reply With Quote
Old 10-09-2012, 05:54 PM   #21
Rewards Points: 558
you can also use a Jancy slugger cutter.
This is the bit
We use this all the time. it is a portable magnetic drill. You also could have had the anchors welded to the underside of the plate.
epson is offline   Reply With Quote
Old 10-09-2012, 06:49 PM   #22
DIY staff
Rewards Points: 7,174
$200 doesn't sound bad-----
I would consider renting a Mag drill if the welder doesn't work out----I've used them plenty of times and they do the job--like Beenthere suggested--use tap oil to cool the bits---
I like the welder idea---
Old 10-09-2012, 08:26 PM   #23
JOATMON
ddawg16's Avatar
Rewards Points: 1,976
Peak....too bad you don't live close to me....I could loan you one for a day.....
I would check out rental costs......you don't want to do it with a hand drill.....I only had about 20 holes to drill in 1/4" plate steel for my beams....I almost broke my wrists a couple of times when the bit caught.....
Without the mag drill, it took 10-15 min per hole
Old 10-09-2012, 08:43 PM   #24
DIY staff
Ddawg---I used to haul the Mag drill up the side of a mixing tank with a block and tackle just to avoid hand drilling.
The most serious accident in my career ,so far, was caused by a drill,---three broken ribs---three weeks off work.
Old 10-09-2012, 09:16 PM   #25
Concrete & Masonry
Rewards Points: 620
Although mag drills certainly work well in the right application, gettign one to attach to concrete to concrete through "magnetics" should prove challenging. Unless the OP was able to find one to rent, and it had allowances to be anchored down toe the concrete with mechanical anchors, I doubt it's much use at this point. Plasma is the way to go in this case IMO........
jomama45 is offline   Reply With Quote
Old 10-09-2012, 09:46 PM   #26
No plasma if it's sitting on concrete. The kerf needs to go somewhere or you'll be buying lots of tips and they're expensive.
lynxpilot is offline   Reply With Quote
Old 10-10-2012, 06:57 AM   #27
JOATMON
ddawg16's Avatar
I don't believe it's on concrete yet.....as I understand it, he needs to drill the holes to match the studs already in the concrete....so I assume the columns are laying on the ground on their sides....with the plates vertical.....pretty much a perfect application for a mag drill....
Old 10-10-2012, 07:40 AM   #28
agree
Old 10-11-2012, 05:23 PM   #29
Paid to have the Welder come out and plasma cut them. We also decided to cut the existing anchors and put 5" new ones in using the new marked(And Square) holes the welder made. He obviously had to cut and grind the old ones down so the plate would sit flat...still only charged me the $200. I will be using him again...
Old 10-11-2012, 05:25 PM   #30
JOATMON
ddawg16's Avatar
Peak....thanks for the update....sounds like a good solution and you got treated very fair.
Removing cut, rust old 1 1/2" steel pipe Pharmtoxboy Plumbing 5 03-11-2012 08:37 AM
How many holes can I drill into a wood stud? lostintyme Building & Construction 8 02-28-2012 07:26 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
recommendations for an all-purpose drill mcvane Tools 18 11-29-2007 09:12 AM
Is the 1/2" Craftsman Drill a goner? KUIPORNG Tools 1 02-26-2007 11:22 AM
