Old 07-23-2009, 05:24 PM   #1
Default what is best outdoor deck material
slats in wood deck are rotting. ....looking for best replacement that does not have to be stained or treated and requires little maitenence....house is in notheast (suburb of NYC)
exqssme is offline   Reply With Quote
Old 07-23-2009, 09:08 PM   #2
red wood or red cedar. my favorites and whats wrong with a little oil once a year or not. just let them turn to a nice grey..
wood decks are the best. Trex and timber tech arent there yet imho.
II Weeks is offline   Reply With Quote
Old 07-23-2009, 11:07 PM   #3
Building codes guy, Mod
thekctermite's Avatar
I never recommend composites, but if you want a MAINTENANCE FREE deck, redwood or cedar are not good choices. To keep them good looking and long lasting, they need to be periodically stained/sealed. They do beat the heck out of treated decking though.
Composites will last forever. They may not look beautiful forever (or even for a year in some cases), but they'll last forever.
Ipe is a very good option if you want real wood. It is in the price range of composites. You can leave it unstained and untreated if you like and it will last for decades with little or no degradation. Awesome stuff.
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
Old 07-24-2009, 10:22 AM   #4
General Contractor
Any wood material will require some degree of maintenance. If you're alright with letting the wood gray with age and depending on your location redwood, cedar, mahogany, and ipe can all be used without sealing/or staining.
I just priced an ipe deck and balusters in my area: $6.30 each (2"x2"x3'). A 2"x6"x18' was $172.60 per piece. 2"x4"x16' was $93.28 per piece. Plugs where 100ct for $19.99. Definitely more expensive than what I can get composite decking for.
If you buy a good quality sealer and pretreat the wood with borate before you seal it, you should only have to re-seal every other year. There is no such thing as a truly maintenece free deck. You should also inspect your deck framing yearly for signs of wear and damage.
ARI001 is offline   Reply With Quote
Old 07-24-2009, 10:34 AM   #5
Are you looking for recomendations for the best composite?
framer53 is offline   Reply With Quote
Old 07-24-2009, 10:44 AM   #6
Extreme DIY Homeowner
Scuba_Dave's Avatar
What do IPE deck boards go for?
Or are the 2x6/2x4 used as deck boards?
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is online now   Reply With Quote
Old 07-24-2009, 11:28 AM   #7
General Contractor
The 2x6 are the deck boards. The supplier I use does not have 5/4" available in Ipe.
Old 07-24-2009, 01:09 PM   #8
Newbie Bill
Wow, that is $9.58 per linear foot for the 2X6. See if your guy can source some 5/4X6 out for you. On line it is going for $2.94 a linear foot.
That Ipe is tough stuff and 5/4X6 is more than sufficient for decking. I saw a demonstration where a guy took a 5 foot long 5/4X6 Ipe deck board, spanned it over its entire length and stood on it.
Yes there was some deflection, but very little. Wow. I'd like to see someone do that with composite.
I wish it didn't cost me an arm and a leg to get the stuff shipped to me up here.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 07-24-2009, 01:28 PM   #9
General Contractor
All the stuff I have seen online that is 5/4" is not planed. If you have some links please post.
Old 07-24-2009, 01:44 PM   #10
Newbie Bill
Hey Ari001,
Here is the site I got the price from
http://www.ipedepot.com/
It is a part of Advantage Lumber.
http://www.advantagelumber.com/
I don't know if their decking has been planed. Noob comment coming... I thought it came sanded on at least 3 sides. Is that what you mean by planed?
Bill
Old 07-24-2009, 01:52 PM   #11
Ok, ok...Maybe Ipe's more money than composite. I was simply trying to illustrate that it isn't on par with the aforementioned cedar, ACQ, etc.
No need for 5/4 ipe on most decks. The 4/4 stuff is a lot easier to stomach for decking and is plenty stiff. I bought a piece of 5/4x6"-8' ipe a couple weeks ago and it was about $50...ouch. But, it'll outlast everything out there and it looks just plain classy.
Old 07-24-2009, 02:44 PM   #12
Scuba_Dave's Avatar
I think it$ out for me
Once we get the addition paid off I can buy better stuff
But the 3 PT decks hopefully will last 20-30 years w/proper maintenance
By that time I may have to hire someone to replace the decking
But maybe not
Old 07-24-2009, 03:30 PM   #13
General Contractor
Hey Ari001,
Thanks for the links. No, I meant rough milled as in plane yourself or pay the mill to do so for you. Most of the mills I've dealt with will charge you if you want it sanded after planing also.
Old 07-24-2009, 03:58 PM   #14
Thanks for all the responses
I will probalbly go with wood.... thought there may be a new product out there that i did not know about and could save work and time regading maintenance......
someone recommended Correct Deck www.correctdeck.com but i have't seen the material......
Any recommendation for a good wood sealer?......I will probably not stain the deck
Thanks again
Old 07-24-2009, 04:03 PM   #15
....i not familr with all latest products and i would not mind a composte as long as it dosen't look to "fake"...... someone told me about Composite Deck www.compositedeck.com but have not seen it
Thanks for the reply
More On This Topic
A new deck may be just the addition your home needs. Patios are perfect for relaxing evenings, backyard barbeques and family gatherings. The process of constructing a deck can be time-consuming and expensive, especially when it comes to buying the lumber... Read More »
In northern climates where snow and ice are frequent visitors to our homes, one question that is asked frequently is, "How do you get rid of ice on a wood deck?" One of the big concerns is if it will harm the wood or deck itself. There are many methods... Read More »
Finishing a deck can seem like an intimidating task with the different products and materials used. However, it doesn't have to be overwhelming when you break everything down into steps and figure out exactly what you need to get the job done. Read More »
Hi this is Drew Finn for expertvillage.com we are going to talk about cleaning and maintaining a deck. This video is presented by Black Dog Video and you can visit us on the web on blackdogvideo.biz. We have cleaned the deck, washed it down, we are... Read More »
Circular Saw Mitter Cuts
Circular Saw Mitter Cuts by Expert Village
In this clip we're going to talk about Miter cuts. Let's take a look at the circular saw, again making sure it's unplugged for safety. With this adjustment, we can change the angle of the base plate, in this case we're going to, it usually has a stop at... Read More »
framing material estimate maydoug Building & Construction 38 06-12-2009 03:32 PM
Ceiling Ventilation Fan rjordan392 HVAC 1 05-20-2009 07:41 PM
Question re: fiber-cement soffit material MichaelinOmaha Carpentry 4 10-12-2006 09:30 PM
What roofing material is right for me? Grumpy Roofing 0 07-07-2004 09:41 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
