What Is This Beam Under My Stairway? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-13-2012, 12:02 PM   #1
Rewards Points: 12
What is this beam under my stairway?
Under the stairs leading from the 1st to 2nd floor are a stringer on each side, and then this beam that runs along the middle. The backside of the steps are about 4 inches away from the beam, so it is not a stringer (at least as I understand it).
The beam is connected at the very bottom of the stairs and at the very top, and at each of those is some extra wood to support the top and bottom steps, but no other steps are supported.
There is a cross beam going across at about 5 feet up, that anchors the beam to either side of the stairwell.
I have included some dark, poorly shot photos. What is this thing, and can I remove it? Is it providing any support? Why is it only connected to the top and bottom steps (and anchored in the middle)? It does move slightly if I give it a good wiggle.
The stairwell originally had a plaster and lath ceiling. Perhaps this beam was only to provide support for the lath?
I would like to remove it to provide better access to storage under the steps. Can I take it completely out?
bigdaddydavy is offline   Reply With Quote
Old 08-13-2012, 12:07 PM   #2
Rewards Points: 14,290
The pictures would not come up on my computer.
Old 08-13-2012, 12:36 PM   #3
Rewards Points: 12
Ok, I changed the images to a different host.
Old 08-13-2012, 01:08 PM   #4
Rewards Points: 502
The photos are a bit dark, and it would be helpful to see the fixings at the top and bottom, but from what you say, it does seem as though it was just a central support for a plaster soffit.
tony.g is offline   Reply With Quote
Old 08-14-2012, 02:26 PM   #5
Stairguy
Millertyme's Avatar
Rewards Points: 508
My guess would be that it was holding up some sort of ceiling. They supported it half way so it wouldn't sag in the middle.
Millertyme is offline   Reply With Quote
Old 08-14-2012, 02:44 PM   #6
Rewards Points: 12
My thoughts indeed... I took it out this morning and am enjoying the new found free space!
Old 08-14-2012, 02:54 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 2,112
Hmmmmmm.....
Per my plans...I have to have type X 5/8" drywall under my stairs.....maybe it's a local thing....
Old 08-14-2012, 03:16 PM   #8
Rewards Points: 12
Originally Posted by ddawg16 View Post
Hmmmmmm.....
I looked under my city code and couldn't find anything referencing not being able to use under the stairs as storage, or requiring any type of ceiling, etc.
Old 08-14-2012, 03:20 PM   #9
It's not a real ceiling, it to seal off the bottom of the stairs so in case of a fire there the last to burn so you can get out.
It's done on all floors of the house if the stairs are open and the area is used for storage.
drilling through steel I beam DIYguy2000 Building & Construction 3 11-21-2011 08:39 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 08:38 PM
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 12:08 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 08:46 PM
