Old 02-11-2011, 03:10 PM   #1
Wet walls
Recently had a porch put up. single block wall plasterboard or lining board on inside, when cold outside the interior wall get wet patches. any ideas and solutions would be gratfully recieved
WILSY23 is offline   Reply With Quote
Old 02-11-2011, 08:17 PM   #2
Wet walls
Without insulation, cold from outside cools down your inner wall covering, moisture in the air condenses on it, giving a well wall. You'll need to insulate the space between your outside block wall and your inner wall covering. What area of the country are you in?
bob22 is offline   Reply With Quote
Old 02-12-2011, 03:23 PM   #3
Wet walls
bob22 many thanks. I live in Devon. could i do this myself?
Old 02-12-2011, 03:36 PM   #4
Tileguy
Bud Cline's Avatar
Wet walls
"Devon"?
Where's Devon?
Is that in the U.S.?
Old 02-12-2011, 07:43 PM   #5
Wet walls
Devon, PA?
You could do it; the question is do you have the skills, patience, etc... to do so. For example, if there are electrical devices/wiring on that wall, you'll be getting involved with that type of work.
Old 02-13-2011, 10:00 AM   #6
Wet walls
bob22 many thanks for your advise i'l have a think about it. And bud cline Devon is in England UK.
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 10:20 AM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 02:20 PM
load bearing walls worriedowner Building & Construction 3 02-02-2011 05:12 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
