Wet Vapor Barrier - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-04-2012, 01:26 PM   #1
wet vapor barrier
My crawl space got water in it from Hurricane Sandy. It never had water before. There is a plastic barrier on the ground. The water has been pumped out.
Should I replace the plastic sheeting?
kato92 is offline   Reply With Quote
Old 11-04-2012, 01:37 PM   #2
Rewards Points: 13,274
Just remove it, flip it over and let it dry out in the yard if possible.
It's not going to go bad, and can be reused.
Get some fans under there and leave the access door open.
If it's going to get below freezing, close the space up and run a dehumidifier.
kato92 (11-04-2012)
Tags
wet crawl space
