Wet Insulation In Bathroom In Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-14-2013, 09:21 PM   #1
Wet insulation in bathroom in basement
I discovered in the bathroom of the basement : the vapor barrier is installed directly on the concrete wall (between the concrete wall and the insulation) ... then the insulation ... then the dry wall (backer-board tiles) ...
I found that the insulation is wet, when I removed some of the insulation, I found condensation on the vapor barrier.
I know that the vapor barrier should be installed between the drywall and the insulation (which is not my case).
My question is it OK to leave it like that ?
Should I replace the wall, the insulation and install the vapor barrier correctly ? if yes .. should i remove the old vapor barrier installed on the concrete wall or I can leave it ?
goal80 is offline   Reply With Quote
Yes, Another Basement Insulation Question Beepster Insulation 7 11-30-2011 06:30 PM
basement insulation help dp683 Insulation 2 11-14-2011 10:20 AM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
Basement Insulation and humidity control mcwolfe6 General DIY Discussions 11 01-28-2010 06:02 PM
Plumbing Help for New Basement Bathroom morphers82 Plumbing 2 03-14-2009 12:17 AM
