Wet Drywall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-09-2008, 07:10 AM   #1
When is fishing season?
CowboyAndy's Avatar
Wet drywall?
Here's what happened...
I had a few sheets of greenboard in the back of my truck as I was replacing some sheetrock in the bathroom. While I was upstairs working, it started to rain/snow. The sheet was exposed to light rain for about 30 min. the sun came out almost imediatly after, and was nice and bright for the rest of the day.
the next day, once it was dry, I moved it from the truck inside. It looks like its okay (no visable signs of water stains or anything). It looks exactly like a new sheet of drywall should.
I know its common practice to wet drywall when bending it.
Is this sheet still any good?
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 04-09-2008, 08:16 AM   #2
Rewards Points: 5,336
Just make sure it's dry before you install it and you should be fine.
Ron
Old 04-09-2008, 02:42 PM   #3
It's fine.
jerryh3 is offline   Reply With Quote
Old 04-09-2008, 05:34 PM   #4
CowboyAndy's Avatar
Thanks guys!
MY HOUSE OWNS ME!
Old 04-09-2008, 09:53 PM   #5
Hey pal,
As long as the wet drywalled dryed out and it was once only wet, it will be fine. As the other reply said also it is common practice to wet the rock before installing in some situations, round walls etc...
mark/ painter48
sprayer48 is offline   Reply With Quote
Superior Walls - Floating Corners & Drywall Woodcutter Drywall & Plaster 16 04-22-2011 12:05 PM
Plaster on drywall? bofusmosby Carpentry 7 03-06-2008 07:30 AM
Replacing 12" ceiling tile with drywall housefixin Remodeling 5 09-09-2007 03:00 PM
General easy drywall question bigboyjoel Building & Construction 3 05-27-2007 08:52 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
