Wet Crawl Space - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-22-2017, 10:17 AM   #1
Rewards Points: 14
Wet Crawl space
Hi,
We bot a new house and a large area in crawl space is perpetually wet. We received few quotes from contractors - some suggesting french drain, some suggesting de-humiidifiers, some suggesting tar liner etc..
Am confused - the quotes range from 3K-8K.
Please advise what's the ideal way to handle this.
Thx, manud
manud is offline   Reply With Quote
Old 01-22-2017, 12:18 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,382
Re: Wet Crawl space
Ayuh,..... The Best way to handle yer house issue, as well as the garage issue, is by gradin' the yard to move the water Away from the buildin's,....
Every situation is different,...
Got any pictures of the place, that might show the grades, 'n pitch around yer buildin's,..??
Surface drainage, via swales is better that subterranean drainage tiles/ french drains,....
Old 01-22-2017, 12:49 PM   #3
ZTMAN's Avatar
Rewards Points: 416
Re: Wet Crawl space
Holy cow. I see a number of threads that you started about your new house. Did you have this home inspected before you purchased?
I don't mind spending money, I mind wasting money.
ZTMAN is offline   Reply With Quote
Old 01-22-2017, 02:53 PM   #4
RRH
Rewards Points: 302
Re: Wet Crawl space
No pics and not enough info.
But normally a drain pipe from crawl space to lower space in the yard. If yard is higher then will need a pump.
RRH is offline   Reply With Quote
Old 01-26-2017, 01:34 PM   #5
Rewards Points: 672
Re: Wet Crawl space
Gutters, downspout extensions and grading to move/keep water away from the crawlspace in the first place.
stick\shift is offline   Reply With Quote
Tags
crawl space , humid
Make Up Air Duct Surround Moisture Problem ProGreen Insulation 10 07-03-2015 07:21 PM
Enclosing crawl space under sun room rankamateur Building & Construction 4 10-16-2014 11:44 AM
Sealing off a Crawl Space arblargan Insulation 12 09-11-2014 10:41 AM
Crawl Space Insulation in NWT Canada too-cold Insulation 3 11-10-2012 02:11 PM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 08:15 PM
