Wet Corner Floors In Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-31-2011, 03:34 PM   #1
wet corner floors in basement
I get water in my basement in the 2 corners where my eaves spouts are. the floor also is wet. what should I look for?
kathy.thornton is offline   Reply With Quote
Old 07-31-2011, 03:35 PM   #2
Rewards Points: 6,652
How far away from the foundation are your downspouts, and are the gutters clean, with no debris in them?
Old 07-31-2011, 04:23 PM   #3
Gymschu's Avatar
Rewards Points: 930
Definitely sounds like a spouting problem. Either they are clogged or your house was backfilled with soil sloping towards your house not away from your house like it should be. First check the entry points into your downspouts for clogs. If nothing is there, you may have a clog in an elbow of your spouting. This may require a bit of disassembly to remove debris.
what's the consequences of a well insulated basement diy001 Building & Construction 1 06-12-2011 01:13 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Insulation for Basement Ceiling under hardwood floors anygren Building & Construction 1 08-24-2010 11:57 PM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
