Wet Basement Walls - New Construction In Winter - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-25-2011, 11:38 PM   #1
Rewards Points: 176
Wet basement walls - New Construction in Winter
My son-in-law is having a house built (in Michigan) and is concerned about the basement cement walls being so wet.
The cement work was done the first and second week of December and the house has been sealed up and heat was turned on January 15th.
They surrounded the exterior walls with 2" foam boards before back filling.
Is this much moisture common in new basement walls?
Also, there is a puddle of water around the well poly pipe coming up through the floor near the pressure tank. Is this common?
Thanks in advance.
Barb
gma2rjc is offline   Reply With Quote
Old 01-25-2011, 11:47 PM   #2
Experienced
Jackofall1's Avatar
The insulation on the outside sounds perculiar to me, from all that I have read, the 2" XPS should be on the inside and the outside should have a water seal, XPS doesn't seal the wall!
http://www.buildingscience.com/docum...ent-insulation
The Following User Says Thank You to Jackofall1 For This Useful Post:
gma2rjc (01-26-2011)
Old 01-26-2011, 06:19 AM   #3
DIY staff
Rewards Points: 7,174
That looks like condensation---what's the humidity level? Is the upstairs insulated and drywalled?
New construction takes a while to dry out--check the furnace--shut down the humidifier if it has one,
Get the heat up and dry it out.
Let's see what others have to say.---Mike---
Old 01-26-2011, 08:12 AM   #4
Concrete & Masonry
Rewards Points: 470
That's condensation as Mike stated. The warm inside air hits the cold area's of the wall that are exposed to the weather and the humid air condensates on the surface. Looking at the pics, I'd guess that the foam either isn't tight at the top of the wall, or it is missing above grade. All of this will be compounded by the kerosene "ready heater" (non-vented combustion put's ALOT of moisture in the air) and lack of insulation upstairs, if that's the case.
jomama45 is online now   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Old 01-26-2011, 08:14 AM   #5
Concrete & Masonry
Rewards Points: 470
Nothing wrong with it on the outside, it's done on all new basements here. It actually helps protect the damproofing coat from damage at backfill.
Old 01-26-2011, 08:14 AM   #6
Rewards Points: 6,652
It is still "Green" concrete, and still curing. Pouring during Winter time, means that it will take longer for the Concrete to set. As for the outside walls, who was it that thought to put the Foam panels on the outside, and did they do any type of waterproofing? I would not be surprised that the moisture is not coming from the fact that you have a warm inside, and cold outside, and with the foundation not sealed, guess where the water is always going to come through at.
Also, it appears that the moisture follows the grade outside, but without pictures from the outside, there is no way to confirm it.
Old 01-26-2011, 08:43 AM   #7
Rewards Points: 176
Thanks everyone.
I think you're right about the condensation. I'll have him check the humidity level down there and tell him to turn the heat up. Would it help to run a couple fans?
The foundation was sprayed with the black stuff. I didn't look to see if the foam board goes to the top of the foundation. I have a couple pics of the outside of the house. I'll take a look at them.
The upstairs is insulated and drywalled (as of last week and I took the pictures on Saturday) The furnace is running, so I don't think they're using the kerosene heater anymore. Except for in the garage, to heat the ground before they pour the cement floor.
Thanks again.
Barb
Old 01-26-2011, 10:27 PM   #8
DIY staff
If they finished the drywall recently--there is a lot of wet mud drying along with the usual moisture from construction---Keep the heat going---DO NOT install any hardwood flooring until the humidity stabilizes.
Keep us posted--Mike--
Old 01-26-2011, 10:55 PM   #9
Registered User
Rewards Points: 4,902
Be glad they did.
Basic;
Installing insulation on the exterior or "dirt side" of a basement wall has the following advantages and disadvantages:
Advantages:
* it minimizes thermal bridging and reduces heat loss through the foundation,
* it protects the damp proofing coating from damage during back-filling,
* it can serve as a capillary break to moisture intrusion,
* it protects the foundation from the effects of the freeze-thaw cycle in extreme climates,
* it reduces the potential for condensation on surfaces in the basement, and
* it reduces the loss interior space when foundation insulation is desired, and
* it conserves room area, relative to installing insulation on the interior.
Disadvantages:
* installation is expensive for an existing building unless a perimeter drainage system is also being installed,
* many exterior insulation materials are susceptible to insect infestation, and
* many contractors are unfamiliar with proper detailing procedures.
From; http://www.espenergy.com/insulating_foundations.htm
Detailed; http://www.buildingfoundation.umn.ed...timum-main.htm
If you liked that…… http://www.nrc-cnrc.gc.ca/eng/ibp/ir.../ctus-n36.html
Insulated those rim joists; http://www.rd.com/57548/article57548.html
Gary
Old 01-27-2011, 01:04 AM   #10
Rewards Points: 176
Thanks for the great information Mike and Gary. I hadn't thought about the humidity level where wood flooring is concerned.
Lots of great information on those websites too. There sure is a lot to know about building a house that most people don't think of.
Barb
Old 01-27-2011, 06:19 AM   #11
DIY staff
Barb
That's why this site is here--Hopefully we can head off some mistakes--
gma2rjc (01-27-2011)
Old 01-27-2011, 06:43 AM   #12
Rewards Points: 4,442
be particularly careful about the exterior grading,,, $ to donuts, the back-filling wasn't placed in compacted ' lifts ' so there will be settling of the disturbed earth back-fill,,, many local codes now require a toe drain about homes' foundations,,, unfortunately, those same codes do not usually include exterior sumps & pumps NOR drainage to daylight
The Following User Says Thank You to stadry For This Useful Post:
Tags
new construction , seeping basement walls , wet basement walls
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 4 12-06-2012 09:26 AM
Damp basement walls cjjjer Building & Construction 1 04-02-2010 05:18 PM
basement walls chuckofaltrades Painting 1 10-27-2009 10:51 PM
Painting Basement Floor and Foundation Walls meth Painting 5 09-26-2008 08:54 AM
Hole in new construction basement wall AprilQ Building & Construction 5 07-08-2008 07:14 PM
