Wet Basement During Wet Weather - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-13-2011, 09:12 PM   #1
wet basement during wet weather
i have a poured foundation with a 4 ft crawl space approx 2.5 ft below grade during heavy rains i get seepage at the cove joint - i also have a sump pump should i seal the joint or take some other corrective action
i live in an aea with high ground water - just off a lake my floor is approx 4 ft above the footings for the walls the grade is ok and there are no tie in to the sump the sump sits in a layer of gravel
bobo175 is offline   Reply With Quote
Old 09-14-2011, 06:51 AM   #2
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
Check for proper grading outside. Make sure there are no down spouts without ends that take the water away from the house. If those things are done you may want to check to see if you have a drain tile around your home. Post your location for more info.
Big N8 is offline   Reply With Quote
The Following User Says Thank You to Big N8 For This Useful Post:
bobo175 (09-17-2011)
replacing weather stripping on front door cao911 Remodeling 5 09-07-2012 05:29 PM
Basement Leak Problem along Brickwall/Driveway side Firehawk734 Building & Construction 1 08-16-2011 06:20 PM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
