West Coast Post And Beam Subfloor Repair Help! - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 12-23-2013, 11:19 PM   #31
I feel all that sub flooring needs to be cut out and replaced.All of the flooring are to damaged so you just use framing with a flat and fixed board don't use the flexible board that should be damaged with specific time of period so use better board .
michelclarke is offline   Reply With Quote
How should I support this post? Pittsville Building & Construction 9 08-02-2013 09:14 AM
New posts and beams in crawlspace, post out of line WillK Building & Construction 1 02-26-2012 09:56 AM
Beam build, joint not over post WillK Building & Construction 8 01-03-2012 09:31 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 08:38 PM
Deck Beam connection to Post? CNJHomeowner Building & Construction 7 08-08-2008 06:14 AM
