Welder For A Beginner - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-29-2011, 09:37 PM   #1
Rewards Points: 77
Welder for a beginner
I would like to get a welder. The project I have in mind is a railing with black pipe newel posts and rebar for balusters. So I would be welding rebar to rebar and rebar to black pipe. I saw on Craigslist a Clark 130en. What do you guys recommend?
bkvanbek is offline   Reply With Quote
Old 09-30-2011, 12:28 AM   #2
Rewards Points: 1,092
I am not familiar w/ anything but "the oldies", like Hobart, Miller, Lincoln, etc, in the welding world. I'd get a descent AC buzz box and use E7018 electrode made SPECIFICALLY for AC. Also, it would not hurt at all to pre-heat the rebar a tad, as it is a bit brittle. Do your best to not undercut when you weld; that will kill the joint as quickly as anything; go slow enough to fill in the void the arc makes. Good luck.
Old 09-30-2011, 12:36 AM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
Not familiar with the one you describing but I would recommend a flux core wire feed welder.
I think you would have better luck and a less steep learning curve that a stick welder.
Andy.
AndyGump is offline   Reply With Quote
Old 09-30-2011, 08:37 AM   #4
Rewards Points: 77
Is a "buzz box" just another name for a arc welder? What type of welder is easier to do a good job?
Old 09-30-2011, 09:01 AM   #5
Rewards Points: 5,336
A Mig welder is almost idiot proof. Lower learning curve then Arc or Tig but still requires more then just opening the box and lighting it up.
I would suggest taking a course in it's use, especially if you're making railings or other structural pieces.
Around here they have a school called BOCES. When I decided to work older cars again, I took a welding course to see which type of welder I wanted to buy. They taught Arc, Mig, Tig and Oxy-acetylene. After we learned how to use each of the devices(2-3hour classes), we would weld for 3 hours for the next 8 classes. If you were interested in getting certified, you could go on and take more advanced courses.
The guy who taught the course was a professional welder.
I ended up buying a Hobart 140 mig welder.
Ron
B. Franklin 1759
Old 09-30-2011, 09:22 AM   #6
Rewards Points: 77
I did take welding in high-school, arc and oxy-acetylene. Not interested in any certification. Mostly this one project, that I can't even get my welder to come do, even if I had the money.
Old 09-30-2011, 09:55 AM   #7
I don't know what you mean by this.
Ron
B. Franklin 1759
Old 09-30-2011, 10:02 AM   #8
Rewards Points: 77
An old friend of mine is a welder, I take stuff to him for repairs, but this railing has to be welded in place. I can't get him out here. And I really won't have much use for the welder after this one project.
Old 09-30-2011, 11:15 AM   #9
Then why did you post," I would like to get a welder"?
Ron
B. Franklin 1759
Old 09-30-2011, 11:20 AM   #10
Rewards Points: 77
Because I want to get a welder, for this project.
Old 09-30-2011, 12:49 PM   #11
Rent one.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
josall (09-30-2011)
Old 09-30-2011, 01:15 PM   #12
Rewards Points: 77
$70 a day for an arc welder. I would rather buy one. So how is the Clarke 130en?
Old 09-30-2011, 01:42 PM   #13
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,726
Ayuh,... Anemic at best...
To weld rebar, ya need at Least a 180 amp machine...
Old 09-30-2011, 04:00 PM   #14
Tractor Supply carries a relatively cheap Fluxcore unit for about $130. I think it only goes up to 80amps, but with this being a railing, you would probably get adaquete penetration, a tack weld sounds like it would be sufficiente in this situation. I welded a truck frame this past spring with and an 80amp welder was more than sufficient, you can always do multiple passes.
Dustincoc is offline   Reply With Quote
Old 09-30-2011, 05:06 PM   #15
Rewards Points: 77
There is a Clarke 130en which is 130amp with cart on craigslist for $250.
240 outlet to welder Chris D. Electrical 8 04-14-2011 03:04 PM
Wiring Detached Garage for 220v welder 8N1949 Electrical 2 03-11-2010 08:47 AM
hooking up welder help? dmank Electrical 1 12-29-2008 11:48 AM
240v Welder powered by portable generator jackgerd Electrical 10 11-06-2008 01:38 PM
Miller syncrowave 250dx Welder installation saddletramp Electrical 6 01-10-2008 01:11 AM
