Weight Bearing Wall Removal Contractors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-30-2013, 05:32 PM   #1
weight bearing wall removal contractors
I need to have a soffit removed from a weight bearing wall, install new laminated beam and 2 post . Add framing and dry wall to replace soffit and finish to prime. What is a reasonable price for this work?
chudson is offline   Reply With Quote
Old 03-30-2013, 05:36 PM   #2
Rewards Points: 13,274
Pricing just not going to happen here, or any place on the net that knows how this works.
Need to make some local calls and have someone see the job on site, anything else is just a usless guess.
What to know how to do it then someone here can help.
Old 03-30-2013, 05:38 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
Welcome to the Forum!
a reasonable price is what a builder will charge that you are willing to pay .... see this link "How much will it cost?" Asking for price estimates here.
you need to contact some local builders and have them provide you with actual estimates, this is the only way you're going to get any realistic pricing.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 03-30-2013, 05:42 PM   #4
Roofmaster
Rewards Points: 2,172
Pricing is not given on this forum, but even if it was, how would you expect anyone to bid a job where:
1. The location of the work is unknown.
2. The size of the opening is unknown.
3. The applied load, and therefore the size of the beam is unknown.
4. What floor the work is on is unknown. (you could live in a high rise)
5. The access is unknown.
6. How big the soffit is, is unknown.
Difficult, wouldn't you say?
Old 03-30-2013, 06:24 PM   #5
are you removing the wall or just the soffit? a reasonable price is what a good contractor in your area charges. get at least 3 estimates and references from all. if possible ask to see some previous work and talk to past customers. what it might cost where I live might be half of what you have to pay.
Replacing load bearing wall KarlJay Building & Construction 4 12-27-2013 04:44 PM
Load bearing wall removal question... Huggins90 Building & Construction 17 01-21-2013 11:07 AM
Load bearing wall removal abjkkc Building & Construction 17 10-03-2012 11:49 AM
Core filling a bowing wall, please assist silverstrike Building & Construction 12 06-16-2012 11:28 PM
Is this wall bearing? adamgram Building & Construction 15 01-18-2011 10:32 PM
