Weeping tile, Need help quickly please!
Here's my situation:
1) My sump pump failed during a heavy spring storm 2) I don't have water infiltation through the basement walls nor floor. 3) Before I rebuilt the basement due to the sump pump failure , a fondation contractor proposed to dig an exterior hole down to the footing opposite to the sump pit location and see it water would poor to the pit. After 30 minutes of splashing the weeping tile with a hose there was no water in the sump pit. Based on this, the contractor concluded 2 things: 1) The weeping tile is not working 2) It must be excavated and rebuild I am certainly no expert but I am not convinced and would appreciate other expert opinion: 1) Is splashing water on a weeping tile a "fail proof" method to confirm it's working? Would putting a hose in the pipe a better method? 2) Could I attempt to locate the location of the problem (drain video) or attempting to clean the clog with high pressure instead of resorting to excavating all around? Thakns for your help. Jean jmdb@rogers.com |
Since you claim you have had no water infiltration thru the walls or floor would make it seem as if your 'weepers' are taking any perimeter water away.
It all depends on where the perimeter weepers are run to. they some times are run to 'daylight' maybe several feet away from the foundation. The depth of the water in the sump hole should determine the ground water level. Unless the perimeter weepers are tied into the sump (not a good idea) as long as the pump (float) is activated when the water reaches a certain point, you should be ok. I do not understand this approach from your contractor. Post back with more detail and we will advise further. |
I don't understand what you're asking.
It takes my hose about 1 minutes to fill a 5 gallon bucket. That's a rate of 150 gallons per 30 minutes. The storage area created by the voids in a 6" thick layer of gravel beneath a 30 x 30 basement slab can hold upwards of 1300 gallons. My hose would have to run almost 9 hours to discharge that much water. Quote:
Response
The soil condition was dry at the time we did the "weeping tile water test"(3 weeks after the flood) and yes the weeping tile is connected to the sump pit). I want you guys to help me confirm if he's full of it or if there's any thruth to his conclusion based on no water flowing in the sump pit after putting water in the weeping tile for 30 minutes. Thanks again. Hope I'll been able to clarify my situation. Jean |
Pipeguy
I guess you just answer me: This water test means nothing. I'd appreciate you just say that. Anyway two foundation contractors confirmed that the weeping tile test conducted by my contractor is not accepted as an industry practice and that I should beware. That's all I needed to know.
Thank you and have a nice day. |
Old thread, but in case anyone has a similar problem ...
>>> Unless the perimeter weepers are tied into the sump (not a good idea) ... The perimeter weepers (whether just inside the foundation or just outside the foundation) are supposed to be tied into the sump (the pit). Symptom of weepers not working correctly is flooding elsewhere in the basement while the pump is working. If the basement would not have flooded had the sump pump not broken down then chances are everything else was working correctly. |
| All times are GMT -4. The time now is 07:22 AM. |
