Weeping Tile Drainage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-10-2011, 12:29 AM   #1
Weeping tile drainage
IF the area cover by small rocks which is over the weeping tile position has a planter box with an open base will this effect the eficiency of the drainage system. The property is constructed on a concrete slab with no basement
myamya is offline   Reply With Quote
Old 02-10-2011, 05:24 AM   #2
Rewards Points: 4,726
only if the soil in the planter plugs the system.
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 10:05 AM
Where do I make my tile cuts for the wall? petsparkle Kitchen & Bath Remodeling 6 04-25-2009 10:00 AM
drainage tile steel Plumbing 2 07-26-2008 09:07 AM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 09:22 PM
