Old 02-09-2013, 03:37 PM   #1
Exclamation
Weakening my floor?
Would it be ok to remove the cross bridging for my ceiling joists for a few days until I can put them back up? There is nothing overly heavy in the room above. Thanks
Mijotter is offline   Reply With Quote
Old 02-09-2013, 03:44 PM   #2
Weakening my floor?
All there doing is keeping the joist from twisting and reducing floor bouncing if there's a floor above.
Old 02-09-2013, 03:48 PM   #3
Weakening my floor?
so it'd be ok for a few days then?
Old 02-09-2013, 04:19 PM   #4
Weakening my floor?
Yes, but why are you taking them out?
There not going to to be able to just be put back in unless you have complete access over them/
You would have to replace them with blocking between the joist instead.
Tags
basement, ceiling, floor, joist
How to repair a concrete floor we just had repaired! timbo59 Flooring 11 01-04-2012 07:15 PM
First Floor Laundry Room Floor Drain install? hammerlane Plumbing 9 10-21-2011 10:12 AM
Dryer duct hole thru band joist & floor joist justplumducky General Discussion 12 10-05-2010 01:31 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 08:45 AM
