We Are Extending Our Driveway But A Small Part Of The Area Is Spongy - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-09-2010, 07:35 PM   #1
we are extending our driveway but a small part of the area is spongy
we are extending our driveay but we have observed that a portion of the area is spongy, what can be done to fix the sponginess before we asphalt it
pinu is offline   Reply With Quote
Old 10-10-2010, 05:13 AM   #2
Rewards Points: 582
The first step is to find out the cause such as a leaking drain etc.
stuart45 is offline   Reply With Quote
Old 10-10-2010, 09:21 AM   #3
Civil Engineer
Rewards Points: 4,770
Spongy ground is often an indication of usuitable soil underneath, such as organic material, saturated loose silt, debris, or a stump pile. You need to dig up the unsuitable soil (if that is the problem) and replace it with suitable material, which consists of crushed stone, coarse sand, or sand/aggregate mix, placed and compacted.
Old 10-10-2010, 11:50 AM   #4
Concrete & Masonry
Rewards Points: 568
Dig out the bad fill as Dan stated, and typically we would replace with dry, absorbant base material like crushed concrete or fractured limestone. Both are readily available here and soak up alot of moisture before becoming unstable.
jomama45 is offline   Reply With Quote
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
Fixing small area of tiles on the wall Curious123 General DIY Discussions 3 09-09-2009 07:41 PM
Need to have driveway paved and graded Mikey Palmice Landscaping & Lawn Care 3 05-20-2009 07:07 PM
recaulking small area CST Painting 1 11-02-2008 03:03 PM
2x100a sub on service main jambud Electrical 17 03-12-2008 09:31 AM
