Which Way Do The Floor Joists Typically Run? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-27-2013, 04:09 PM   #1
Rewards Points: 578
Which way do the floor joists typically run?
I know this might sound like a dumb question but i need to know.
This is the layout of rooms on the second floor of a home. The red lines indicate location of two impact beams, on either side of the stairs.
Would the floor joists typically run side to side, or front to back?
I know this isnt much to go on, but if you build houses for a living, which way would you typically run them? Parallel with the impact beam or perpendicular?
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
Old 06-27-2013, 04:39 PM   #2
Rewards Points: 2,064
It's difficult to say. Advertisements have a third of your picture/drawing and text covered.
The Following 2 Users Say Thank You to SeniorSitizen For This Useful Post:
Gary in WA (06-28-2013), jbfan (06-27-2013)
Old 06-27-2013, 04:52 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
fairviews.. you need to download adblocker if your having that problem.
as for the joists, based on the wall layout i would say from right to left as the walls along the stairwell are probably bearing walls
woodworkbykirk is offline   Reply With Quote
Old 06-27-2013, 04:59 PM   #4
Rewards Points: 502
As Kirk, perpendicular, as that looks to be the shorter span.
But what's the problem?
tony.g is offline   Reply With Quote
Old 06-27-2013, 05:37 PM   #5
General Contractor
CENTERLINE MV's Avatar
I concur
CENTERLINE MV is offline   Reply With Quote
Old 06-27-2013, 05:58 PM   #6
Civil Engineer
Rewards Points: 4,942
I have never heard the term impact beam. Is that some sort of Texas slang?
Daniel Holzman is online now   Reply With Quote
Old 06-27-2013, 07:08 PM   #7
MarginallyQualified
Rewards Points: 2,464
The second floor joists will typically run the same way that the first floor joists do. Have a basement or crawl space? Go look.
The Following User Says Thank You to TarheelTerp For This Useful Post:
oh'mike (06-28-2013)
Old 06-28-2013, 07:46 AM   #8
Rewards Points: 578
Thanks everyone. No problem really, just needed to know which direction my joists were running in. Thanks for the help.
Daniel, i used to watch all of those remodel shows on diynetwork and thats what they always called the big heavy structural beam in the loadbearing walls.
Old 06-28-2013, 10:37 AM   #9
Mold!! Let's kill it!
Rewards Points: 2,012
Complete Mobile Home Remodel
Mobile homes don't have floor joists.
Old 06-28-2013, 12:21 PM   #10
Rewards Points: 578
its not a mobile home. MY house is. THIS house is not.
Asking for help in understanding a fault scenario in a typically wired house. ChantryOntario Electrical 55 04-26-2013 11:04 PM
What relay points are typically needed for a central air install? Red Squirrel HVAC 1 03-30-2013 04:39 AM
How hot does it typically get in the main plenum of a furnace? Red Squirrel HVAC 15 02-29-2012 02:32 PM
Floor preperation for Tiling Stilgar1973 Flooring 8 01-03-2012 02:54 PM
Does this typically require an inspection?? mopowers Electrical 24 03-11-2010 01:54 PM
