Waterproofing A-- Soon To Be Built-- Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-19-2011, 10:26 PM   #1
Question
Waterproofing a-- soon to be built-- Deck
I have started work on my new 60'x app. 14' Deck. I plan to seal (waterproof) the underside of the deck boards.
I don't really know what to call this type deck constructions and I would like some suggestions and ideas.
I want a nice looking deck that I can place lawnmower, utility trailer, and other items under without a water problem.
I owned a home, a few years ago, that I mounted clear fiberglass roofing to the underside of the floor joist and allowed slope for drainage. It worked very well but was not attractive.
Any suggestions would be appreciated.
Giles is offline   Reply With Quote
Old 03-19-2011, 11:28 PM   #2
Would think that would be similiar to seeing the balconies on homes. If you want it to be a bit more attractive, build it down at the bottom, incorporate it together such as a roof, and be able to have the proper drain, even a gutter, and go from there. Is how I have done it with Balconies anyways.
cwrose79 is offline   Reply With Quote
The Following User Says Thank You to cwrose79 For This Useful Post:
Giles (03-19-2011)
Old 03-20-2011, 01:31 AM   #3
Registered User
Rewards Points: 5,216
The deck should be built to minimum Code, the waterproof roof inspected at that time; http://www.lancova.com/deckinfo.pdf
Be sure to leave egress for any basement windows...
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Giles (03-20-2011)
Old 03-20-2011, 10:02 AM   #4
mem
Rewards Points: 156
I've seen products like this! Try googling 'under deck drainage system' for some choices.
mem is offline   Reply With Quote
Deck stain project gone bad - HELP brownnl Painting 13 03-15-2011 02:57 PM
waterproofing exterior deck for tile sfgreg Flooring 0 11-16-2010 12:19 AM
Fasten deck board from under deck resonator Carpentry 14 09-20-2010 11:15 AM
Need advice on deck flashing, water stain Durt Ferguson General DIY Discussions 4 04-20-2010 06:09 PM
built a new cedar deck used galvanized instead of screws should i replace all nails? abbyaudi Carpentry 8 04-19-2010 11:57 AM
