Waterproofing Holes? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-19-2008, 05:25 AM   #1
Waterproofing holes?
We just drilled two through our foundation wall for conduit allowance. One is 5" and the other is 2".
-The first layer is 4" block that supports the brick above.
-The second is concrete filled block.
There below grade, how would I properly waterproof these holes?
TonyGG is offline   Reply With Quote
Old 06-19-2008, 08:12 AM   #2
Registered User
Termite's Avatar
If there is an annulus around the conduit that would allow you to pack it with hydraulic cement, that would be my recommendation. Mixed to about the consistency of peanut butter, hydraulic cement is very workable and can be forced into the gap. It won't shrink as it dries, so it is great for sealing gaps and cracks in foundations below grade. It is sold in small bags or tubs.
Caulk is a poor option, and I would avoid it.
There are other epoxy-type sealants that would work well also. They'd have to be bought from a construction specialty supplier, not a box store.
Old 06-19-2008, 10:23 PM   #3
Thanks,
I bought a 5 lb. bag of the hydraulic cement.
Can this cement be mixed too allow it to flow, more watery?
Old 06-19-2008, 10:44 PM   #4
Registered User
Termite's Avatar
I'd avoid doing that. With concrete-type products, more water equals less strength in the finished product.
Aim for a plastic, peanut butter consistency. Use a margin trowel or something similar to pack it into the gaps.
Old 06-20-2008, 11:06 PM   #5
peanut butter mix it is...
thank you KC!
Old 06-21-2008, 05:33 AM   #6
for best results, do the packing from the outside, too,,,coat patch w/asphalt roofing cement several times over DRY block if possible.
yesitsconcrete is offline   Reply With Quote
Engineering help request: drilling holes in a deck joist, supported by a post Deck Building & Construction 14 05-31-2008 10:16 PM
OK to drill holes in top plate to run conduit? troll5501 Carpentry 4 05-11-2008 08:33 PM
Color problem with filled nail holes alternety Painting 3 11-04-2007 11:16 PM
drilling vent holes ape Roofing/Siding 4 10-15-2007 04:36 PM
door with wrong holes for new handlw davedla Carpentry 7 09-26-2006 07:49 PM
