Waterproofing Garage Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-18-2012, 02:37 PM   #1
Rewards Points: 308
One of our tenants called complaining about the garage door flooding when it rains, getting to some of her boxes in storage. Yesterday, I went over to install a floor-mounted rubber threshold like we have here at the house (which work well). I realized when I got there that there is a wooden ridge threshold thing that the door hits on. With that said, I can't mount the rubber threshold on the wooden piece. Not even sure it can be pried up.
Any ideas?
smokey847 is offline   Reply With Quote
Old 12-18-2012, 03:00 PM   #2
Missouri Bound's Avatar
Usually the rubber gasket fits on the bottom of the door. Have you tried to do that? And I'll be that wooden ridge "threshold thing" is keeping water in rather than keeping it out. Is that accurate?
Do you want it your way or the right way?
Old 12-18-2012, 03:29 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
does the garage floor slope towards the opening. and is the driveway properly sloped to allow for proper drainage away from the door
woodworkbykirk is offline   Reply With Quote
Old 12-18-2012, 06:12 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 606
Ayuh,.... My 1st thoughts as well,.... I'm guessin', No, 'n Nope...
To the Op,... Caulk the existin' threshold to the concrete...
Old 12-19-2012, 01:47 AM   #5
Rewards Points: 308
It's an old house, so I don't imagine the drainage is proper. Would you recommend just a clear silicone caulk?
Old 12-19-2012, 09:32 AM   #6
Rewards Points: 13,270
Got a picture?
Old 12-23-2012, 12:45 AM   #7
Rewards Points: 308
Sure, the garage door closes right at the peak of the wood. Sorry it's so big.
Old 12-23-2012, 06:14 AM   #8
Rewards Points: 4,534
even if you caulked it, the door still won't be watertite,,, am guessing the wood is probably an old form that wasn't removed,,, either chop it out & do it right OR get a bodacious big umbrella for the property nothing is going to prevent water intrusion UNLESS the drainage is right,,, even ships leak below the waterline we just remediated a leaking door by trenching in front of it & draining the rainwater to the side & downhill after thatthey had a gasket, too
Door recommendations from basement to garage Tyrus3 Building & Construction 7 07-20-2012 09:12 AM
How to find a garage door dealer meburdick Building & Construction 5 06-28-2011 09:29 PM
Garage Door Assistance dukes32 General DIY Discussions 2 06-15-2011 01:11 PM
Garage Door Install Opinions detailedEye Building & Construction 4 03-31-2010 11:15 PM
Old Genie Garage Door Opener cmgith General DIY Discussions 3 11-27-2006 09:53 PM
