Water In Yard - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-07-2011, 01:06 PM   #1
water in yard
my house when rain or snow always water, my house lower than others house also, this time we looking for built the new house, what we can do?
may we have to raise the ground?
leeo is offline   Reply With Quote
Old 04-07-2011, 02:29 PM   #2
Well, if you raise the ground, your foundation will still have to go down to where it would have been (under frost line) so really what you are doing is changing the grade of the land, so that the house is not the lowest point.
You can run "French drains" around the house, or add a sump or dry well to the property.
I'm not a pro, but I know what you are going through!
Vince
Vincer is offline   Reply With Quote
Old 04-07-2011, 05:18 PM   #3
Rewards Points: 5,332
Post some photos of the site.
Ron
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Water leak, over 1 gallon every 5 minutes. carl1864 Plumbing 13 01-15-2010 12:31 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
