Water In Wood Stove Pipe. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-14-2011, 08:28 AM   #1
Water in wood stove pipe.
Hi,
I've recently removed a wood stove from my basement in order to open up the space.
I decided to put some insolation in the remaining pipe, then cover it with vapour barrier and tuck tape it sealed so it didn't draw heat out.
I've noticed now that after about a month there is maybe around 1-1/2 cups of water sitting in a pool in the vapour barrier. I asked a carpenter friend and he said it was probably condensation....Just thought I would get a second opinion.
Thanks for your help, Although I've used this site as a resource in the past, tis is my first post.
luther is offline   Reply With Quote
Old 02-14-2011, 08:37 AM   #2
Experienced
Jackofall1's Avatar
Welcome Luther, to the best DIY'r site on the web
Was the openning complete sealed off? and what is the top of the flue pipe look like?
Mark
Old 02-14-2011, 08:50 AM   #3
I have a drop ceiling in the basement so the opening is accessible.
As I said the opening, from the inside, was sealed with plastic and tuck tape. I didn't do anything outside.
The top looks like this (I didn't want to go out in the snow to take a photo so you get this kindergarden drawing instead):
Old 02-14-2011, 08:58 AM   #4
Experienced
Jackofall1's Avatar
The fact that the openning was sealed completely, not allowing any air flow, I would say the water you have found was either rain or snow melt.
Mark
Old 02-14-2011, 10:11 AM   #5
Should I seal the top then?
Old 02-14-2011, 10:33 AM   #6
Experienced
Jackofall1's Avatar
Yes that is what I would do.
Is it a masonary chimney?
Old 02-14-2011, 01:30 PM   #7
No, it is metal stove pipe.
Old 02-14-2011, 01:46 PM   #8
They are segmented. You can probably take the cap off, put a piece of plastic on it, and put the cap back on.
pyper is offline   Reply With Quote
Tags
basement , renovating , stove pipe , water collection , wood burning stove
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
loud jackhammer-like noise from hot water pipe omar Plumbing 15 01-08-2012 02:53 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 06:23 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
