Water In Wood Stove - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-05-2012, 01:40 PM   #1
water in wood stove
I finished installing a woodstove and 6 in. single wall stove pipe. All jooints with male down as per instructions. Water is running down pipe and into stove from the ouside.....any suggestions?
Bruce Simmons is offline   Reply With Quote
Old 03-05-2012, 01:50 PM   #2
Rewards Points: 12,794
Is there a cap on the pipe outside?
I hope this single wall pipe is inside not outside. Even then I would have gone with double walled for fire safety.
Old 03-05-2012, 04:29 PM   #3
water in wood stove
yes I have a cap on it....and yes I did use single wall outside....its a metal building and I extened the pipe 2 foot above roof line
Old 03-05-2012, 04:58 PM   #4
Rewards Points: 16
From your description, it is unclear weather the water is running inside or outside the chimney pipe. Assuming the water is running on the outside since the chimney has a cap, did you install a storm collar on the chimney? What type of flashing where the chimney penetrates the roof? And typically the top of the chimney needs to be 2 or 3 feet (some jurisdictions 4 feet) above anything within 10 feet (although this probably isn't causing your water problem).
daveb1 is offline   Reply With Quote
Old 03-05-2012, 05:04 PM   #5
water in wood stove
6 in pipe goes out side wall about 4 ft. above stove the makes a 90degree turn up about 6 ft to roof line
Old 03-05-2012, 05:08 PM   #6
How about a picture of your set up.
I'm no expert but looking at it from a logical stand point if the male side is down it would allow water to get in at every joint as it runs down the pipe.
I never use single wall pipe on any wood stove. After the first year all the finish is burned off and will start rusting from then on.
Did you run this pipe out a side wall then go up or is it straight up and out the roof?
Old 03-05-2012, 05:20 PM   #7
joed's Avatar
Rewards Points: 11,518
While the stove is burning or sitting idle?
Old 03-05-2012, 05:44 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
That is what I think also, condensation from stove not burning hot enough.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
adding wood stove to boiler flu? wombosi HVAC 7 12-14-2009 06:27 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
