-   -   Water Under Garage Door (http://www.diychatroom.com/f19/water-under-garage-door-55809/)
leted_82 10-24-2009 12:51 AM
What is the best way to correct water going under my overhead garage door. There is a seal on the bottom, but the concrete right in front of the garage door slopes slightly toward the door. A pretty good amount of water still makes it in which I would like to prevent. Any ideas would be greatly appreciated. Thanks!
Just Bill 10-24-2009 05:45 AM
Those bulb seal help, but there is no way to make them contact the floor 100%. The only way to fix the problem is to cut the floor at the door and redo it with the proper slope.
user64621 10-24-2009 08:41 AM
leted,
What we do is snap a line a half inch in from the outside of door (under the door) about a quarter inch. Then grind from the line out to get the slope needed.
I should ask,... is rain water flooding back in the garage or just rain + wind?
Almost all concrete guys do door cutouts which makes that pitch away when they pour, but on older floors not seen very often.
Salem747 10-24-2009 09:02 AM
You can get a concrete wheel from most hardware stores and you'll need a good angle grinder. as in the previous post. This is the only way to really fix the problem permanently.
It will take some time with a 4.5" angle grinder but just keep working at it AND WEAR SAFETY GLASSES!!! This will create LOTS of dust so be prepared for that.
vsheetz 10-24-2009 10:06 AM
I had the problem of blowing wind driving water under the garage door. Installed one one these door seals a few years ago - problem solved. YMMV due to your slope issue.
http://www.amazon.com/16-Park-Smart-...396593&sr=1-13
testerdiyc 08-02-2010 01:27 PM
Originally Posted by user64621 (Post 344806)
leted,
Hi.
What is the quarter inch you are referring to?
Will a 4.5" angle grinder really be capable of doing this? I was assuming I would need something much larger with a water hookup for dust control.
stadry 08-02-2010 03:44 PM
im-n-s-h-fo, you need to divert the wtr 1st,,, have the same trouble at our home + garage floor slopes to the rear where it puddled & ran under the family room,,, slot drain at the entrance solved it + 3hrs w/6" grinder & diamond cup wheel,,, yes, dusty BUT now dry :thumbsup:
testerdiyc 08-02-2010 04:11 PM
I have a place for the diverted water to go but there is not enough slope in the concrete from the spot where the door closes outward.
I may buy and larger grinder and a diamond cup wheel and give it a try.
I can't believe that no one has invented a garage door sweep...
itsreallyconc, how wide was your doorway. How much did you grind it down?
Thanks.
stadry 08-02-2010 04:23 PM
std 16' width - door seal to edge of crete was 8" - took it down 3/4",,, rent UNLESS you need it for future work ( we have 6 6" grinders ),,, best place i've found to buy cup wheels is from ' fc727 ' on ebay,,, get the turbo wheels rather'n anything else,,, we also have shrouds on our grinders which're hooked up to nilfisk vacs.
testerdiyc 08-02-2010 04:28 PM
How far inside from the front of the door does the slope need to start? Do I need to go the full thickness of the door? I had someone grind from the front/face of the door to the 8" edge of concrete and that didn't help at all.
Which brand of shroud and grinder did you use?
stadry 08-02-2010 05:11 PM
we buy our shrouds from either joe due or dustmuzzle & have milwaukee, aeg, & bosch grinders,,, you'll rent a sawtec from an apron store w/?'s shroud,,, i snapped a line at the outside edge of the door where the gasket sits on the 'crete,,, don't forget conc repairs & wtrproofing are 2 of our work items so our equip's good stuff,,, learned a long LONG time ago there's no such thing as a good cheap tool,,, when you use any tool, you want the best you can find,,, that's how you tell the pro's - by their tools, knowledge, & attitude.
what was the drop of your grind in the 8" ? ? ?
Mike in Arkansas 08-02-2010 09:30 PM
Thanks.
Wanted the same thing and the only one I could find online was this one
http://www.new-eskimo.co.uk/garage_doors.html . Unfortunately, it's a British company and I could find no US distributors but you might want to try yourself.
stadry 08-02-2010 09:43 PM
try looking at it this way, then,,, think of your basement as a ship's hull below the waterline,,, few can appreciate why basements leak,,, canal lock gates leak, too,,, you'd be trying to build a dam to keep water from infiltrating,,, if canal builders can't, how can we ? ? ?
testerdiyc 08-03-2010 08:58 AM
Are shrouds specific to the brand/model of grinder? I went to Lowe's last night to look at grinders and shrouds and none of the grinders they were selling had shrouds.
Is sawtec poor quality?
The drop for the already grinded 8" is a little over 3/4".
I'll take few pics later today of my existing doors and how they contact the slab. Maybe you can determine something from the pictures.
If anyone happens to have any pictures or links to pictures of what a properly sloped/grinded door should look like I'd appreciate them. Thanks.
testerdiyc 08-03-2010 09:01 AM
I ended up finding another UK company with them. "Wilkes", I think.
I wouldn't mind giving this one a try:
http://www.new-eskimo.co.uk/images/garatite_epic.jpg
