Water Supply Line Runs Through Footing Site - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-15-2011, 12:56 PM   #16
Learning by Doing
Leah Frances's Avatar
Don't we have someone here who usually says: Before you dig. Every dig. It's the law. http://www.missutility.net/
In my town the utility company will come out the next day for homeowners and mark all utilities. The reason I bring this up, is I am presuming you didn't call, because you didn't know the line was there. And.......
I too live in an old house (1805) I have at least two pipes on my property that 'look' like water lines (in fact, they are water lines) but they are not associated with my local utility. They are lines that ran from the well (that is in my basement) out into the yard.
Last. In my town I am responsible for the water line from where it joins the city line to my house - I do have a utility easement (I actually have two). But any problems with the line are my problem. I try to avoid doing things now that will/may make my life harder later.
There is clearly a divergence of opinions on this matter a number of very experienced people have weighed in. Ultimately, you have to decide.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-15-2011, 12:59 PM   #17
I ask the impossible!
Rewards Points: 640
Yeah, but they don't mark utility lines under your crawlspace anyway, and when they mark utilities then you're only supposed to hand dig around those areas - which is what I'm doing anyway. I did the first round of digging with a garden trowel.
WillK is offline   Reply With Quote
The Following User Says Thank You to WillK For This Useful Post:
Leah Frances (03-15-2011)
Old 03-15-2011, 12:59 PM   #18
Learning by Doing
Originally Posted by WillK View Post
And maybe I'm an engineer myself, am I being paranoid? I'm a mechanical engineer working in automotive, not a structural engineer with a PE license.
Told you engineers are paranoid. Mech E in automotive....wish I'd had the forethought as a pup to pursue that. Cool.
Old 03-15-2011, 01:00 PM   #19
Concrete & Masonry
Rewards Points: 530
At least here, the locator's provided for free by your local utilities ONLY mark utility owned lines, and certainly will not go into your home to mark those lines. They will mark your water line to the meter, or where it penetrates the home.
jomama45 is offline   Reply With Quote
Old 03-15-2011, 02:39 PM   #20
Originally Posted by itsreallyconc View Post
you need to sleeve the wtr line PLUS add more conc & steel reinforcement,,,l IF you want to build properly, exceed your local rqmts,,,think of them as union labor just doing the minimum
You live in WI??? Just wondering...
pjordan4477 is offline   Reply With Quote
Town water supply line code. ds211 Plumbing 3 03-10-2011 11:32 AM
Gray PCV for water supply line - is this OK? Jim S. Plumbing 13 08-09-2010 10:20 AM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 10:26 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
