Water Seeps/leaks In House From Rain - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-04-2011, 04:29 PM   #1
Rewards Points: 18
Water seeps/leaks in house from rain
So I've been living in a rental house (slab-on-grade) for over 1.5 years now, and every time it rains, without fail, water seeps in from the east side of the house onto the carpets and a little bit around the corner on the south side. There 2 bedrooms and 2 bathrooms on this side of the house, and there is no evidence of the leak in the bathrooms (at least that i can see), because one bath room has a bathtub along the side of the house, and the other has tile. The landlord's response has been to send out commercial carpet drying fans and fix one thing at a time, as he has no idea what's leaking. Here's a list of things that have been done, all of which have had no improvement:
*Rain gutters
*Remove lawn on that side of house (thought the sprinklers might have caused it) and replace it with a plastic sheet and rocks
*Put sealant on the side of the house
*Installed french drain along the east side of the house, removed plastic sheet.
Yesterday, they removed a planter on the north side, since it was adjacent to the wall on the north side, thinking water could be coming from there. I'm doubtful it is going to work. I think his next idea is to replace the windows, which I wouldn't mind, but I'd like less guesswork and more results, especially since I have mild asthma and all this mold I've been breathing in the meantime is not a good thing.
Any ideas on how to fix this issue?
Water seeps/leaks in house from rain-house.jpg
jamesm113 is offline   Reply With Quote
Old 04-04-2011, 07:32 PM   #2
Rewards Points: 2,238
Hi! jamesm113
Post some pictures of the exterior of the building.
Some back from the building for an "overview".
Some a little more close up.
Welcome to "DIY"!
rossfingal
rossfingal is offline   Reply With Quote
Old 04-04-2011, 07:38 PM   #3
Oops!
Maybe you should welcome me to "DIY"!
RF
Old 04-04-2011, 07:54 PM   #4
Welcome to "DIY"
Welcome to "DIY" big guy!!!!
Originally Posted by rossfingal View Post
Oops!
RF
shastagoathdr is offline   Reply With Quote
The Following User Says Thank You to shastagoathdr For This Useful Post:
rossfingal (04-04-2011)
Old 04-04-2011, 08:41 PM   #5
Rewards Points: 4,452
obviously the wtr's not being correctly managed,,, we regularly install exterior sumps & pumps for condominiums blt 1/2 below grade,,, never have had a problem w/this method,,, we also do it for dwellings on slabs - no problems, either,,, just be certain of the offending wtr's source !
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
