Water Seepage From The Walls?! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-05-2014, 03:19 PM   #1
Rewards Points: 97
Water seepage from the walls?!
My parents house is getting water seepage some some of the corners around the house. Not every corner has water seepage, but some. I feel the upper portion of the corners and they are dry. I feel near the foot of the wall and they are wet. All the walls where they have this water seepage is located adjacent to the exterior (not sure what it's called) of the house. The interior walls and corners are fine.
I look around outside the house and don't notice any cracks along the foot of the house. I didn't do any digging and look for cracks beyond what is visible.
They live in the midwest. Their house is a single story house, no basement.
Any ideas? How do I fix this?!
edta1 is offline   Reply With Quote
Old 04-05-2014, 03:37 PM   #2
Rewards Points: 6,652
Is this a Slab, or on a Crawlspace? If the main floor walls are showing water seepage, then we need pictures of the outside of the house on all four sides. If at the base, then grading around the outside being too high, if the house is on a slab. If on a crawl, then we need pictures inside the crawlspace also.
If this has been going on for a really long time. You are talking about some nasty stuff behind the outside siding, stucco, brick, whatever covers the outside. And some really nasty stuff inside the walls. Soaked insulation, Black mold, rotted plates & joists. The list goes on.
Old 04-05-2014, 03:37 PM   #3
Rewards Points: 452
Is there snow on the roof?
Old 04-05-2014, 04:24 PM   #4
Lightfoot's Avatar
Rewards Points: 272
corners?
check the gutter downspouts, make sure they are pitching water far enough away from the house, and that the dirt is not sloped towards the house.
Flashlight: A cylindrical container used to store dead batteries
Lightfoot is offline   Reply With Quote
The Following User Says Thank You to Lightfoot For This Useful Post:
Gymschu (04-06-2014)
Old 04-05-2014, 04:29 PM   #5
Rewards Points: 97
We don't know how long this has been going on. The house has seen some pretty rough rainstorms. This is the first winter they went through. We just started noticing this problem a few weeks ago. On one of the said corners we noticed mold creeping up. I treated it with some mold killer spray. I know this only kills the exposed mold but doesn't treat the underlying water seepage problem.
The house doesn't have a crawlspace. So it'd be slab? Where do you need pictures? Will I need to dig?
No more snow on the roof.
What other information do you guys need?
Old 04-05-2014, 04:31 PM   #6
Rewards Points: 97
Originally Posted by Lightfoot View Post
corners?
I think one of the corners has a gutter downspout directly outside. I can extend that. The other corners don't have downspouts.
If water is getting in because of a downspout not pitched properly, does that mean there's a crack and water is seeping through this crack?
Old 04-05-2014, 04:58 PM   #7
Rewards Points: 12,882
No idea without the correct info and some pictures of the outside of the house.
No close ups needed.
Often times a slab home can have water come in under the walls if the slab was pored to low and it was not graded correctly.
Mulch piled up against the foundation, landscape timbers forming pond up against the side of the house can all cause water issues.
Old 04-05-2014, 05:02 PM   #8
Rewards Points: 452
If there was snow within the last 2-3 weeks or possibly more that could be a concern being it takes mold some time to appear depending on temperature and moisture conditions.
Old 04-05-2014, 11:45 PM   #9
Rewards Points: 97
What kind of pictures do you need? Foot of the house roughly where the seepage area is?
Often times a slab home can have water come in under the walls if the slab was pored to low and it was not graded correctly."
This doesn't sound like a DIY job.....
Old 04-06-2014, 11:16 AM   #10
Master General ReEngineer
Bondo's Avatar
Rewards Points: 358
Ayuh,.... water flows downhill,... it Could be the roof leakin' runnin' down through the wall, 'n yer seein' it at the bottom of the wall,...
Pictures of the corners of the buildin' will be a good start,...
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 01:59 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 03:50 PM
