Water Seepage Damaging Window Corner - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-21-2011, 06:13 PM   #1
Hello,
Foreclosure property purchase has water damage. Had a termite inspector come and verify there are no termites. It looks like the corners are soggy and damaged. The windows seem to work just fine and the damage is only in the corner. I was told to come have a stucco expert come and analyze the damage to determine the "root of the cause and the scope of damage". It is a foreclosure townhome that was built in 1999 in Houston. Any idea what they would recommend and costs involved to repair? Does the entire window need to be changed out or is there an easier/just as effective solution?
2 pics on link
http://imgur.com/KvE4m
Water Seepage Damaging Window Corner-windowdamage1.jpg   Water Seepage Damaging Window Corner-windowdamage2.jpg
skipe99 is offline   Reply With Quote
Old 02-21-2011, 06:27 PM   #2
DIY staff
Rewards Points: 7,174
Pictures of the outside are needed---Is it real stucco or Dryvit?
Old 02-22-2011, 09:35 AM   #3
Outside shows no damage whatsoever. You would not be able to tell that the window looks like that on the inside from looking at the outside. I am unable to post pics at this time, but can try to get some up later.
I believe it is stucco as that is what is listed on the real estate agent information sheet and in har.com.
I
Old 02-22-2011, 09:36 AM   #4
I think the leakage is due to faulty window installation. not sure though
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
