Water Runs Over Gutters - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-13-2010, 09:29 AM   #1
Question
Water runs over gutters
The fascia on my house is angled back towards the house causing the gutters to hang back at an angle. When it rains heavily the water rushes over the top of the gutter. Should I remove the fascia and add shims to the roof joists to make them parallel to the walls? The gutters are already installed as high as they can be to the roof.
pmalinow is offline   Reply With Quote
Old 06-13-2010, 11:10 AM   #2
If the gutters hang back at an angle then you have the wrong hangers.
hayewe farm is offline   Reply With Quote
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Hot water air blockage pontiac Plumbing 0 05-23-2010 09:08 AM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
Low Hot Water Pressure jifisher Plumbing 10 07-27-2009 06:48 AM
