Water Run Off In Shed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-08-2009, 08:42 AM   #1
river rat 33 yrs.
water run off in shed
Any one who can tell me how to water proof a shed which is getting a river flowing through it? We had our concrete worker pitch the walkway from the house, and he did such. However, now the shed that is about 10ft from the house gets wet every time it rains. The shed floor is below grade, and concrete. One of the issues is that the shed roof does not have rain gutters. The other issue is that the concrete walk to the house butts up against outside shed wall. The shed does have metal flashing, but is there some sort of caulking that would bond to concrete and the flashing? Thanks, Kathy K
kathy k is offline   Reply With Quote
Old 08-09-2009, 02:31 AM   #2
morningwood
Why not raise the shed? Jack it up and put some skids under it...4x4, 6x6 anything really..just make sure it is treated lumber. A shed is easy to jack up. Raised up it last much longer. No water damage and the floor stays dry (inside and out).
Not sure if you get snow down there, but it makes it easier for opening the door in the winter as well. Even if you dont get snow, you get rain and raising the shed should solve your problems from ground water getting in. It wont however solve any issues if the rain gets in on the roof or eaves.
Hope that helps.
rahfiki is offline   Reply With Quote
Old 08-09-2009, 08:22 AM   #3
Kind of hard to raise up a concrete floor
Concrete is porous & soaks up water
Is it just wet, or do you have water running into the shed?
Sounds like a lot of water running in
Best way is to dig down outside & build a drainage trench
Isthere a low area nearby where you can direct the run-off?
Old 08-09-2009, 03:00 PM   #4
morningwood
Ahh--missed the concrete floor part ya that poses a problem raising it....
Old 08-09-2009, 04:29 PM   #5
Framing Contractor
She can try "Mudjacking" if there is a company that does it near her.
Joe Carola
Joe Carola is offline   Reply With Quote
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 04:01 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
