Water Proofing New Construction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-21-2013, 10:55 PM   #1
Rewards Points: 31
water proofing new construction
I am building new construction. Will adding extra gravel (limestone 12-24 more inches) on top of drain tiles increase more drainage therefore enhancing better water proofing. or what is a better choice
jbillups is offline   Reply With Quote
Old 03-21-2013, 11:40 PM   #2
747
registered
747's Avatar
Rewards Points: 534
spray foundation with a 100 percent rubber product or synthetic equal.
747 is offline   Reply With Quote
Old 03-22-2013, 05:58 AM   #3
Rewards Points: 4,454
bentonite sheets are another method however more expensive than spray'd mtl ( rub-r-wall or asphalt emulsion ),,, conc is better choice for bsmt walls,,, a ' toe drain ' should be alongside the footer ( NOT below OR above ),,, when wtr collects in the 4" pipe ( hdpe OR pvc ), direct it to a sump & pump OR drain to daylight,,, don't forget to line the pipe excavation w/soil cloth
Old 03-22-2013, 07:25 AM   #4
Rewards Points: 12,886
I can not imagine using lime stone for a drainage back fill.
Seems to me like it would be to compactable and act more like concrete then a permiable material.
Around here all we use is #57 stone.
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 01:47 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
