Old 12-01-2006, 03:24 PM   #1
Water proof sheathing. Has anyone seen it?
If you have seen it or used it what part of the country are you in?
http://huberwood.com/zip/zipwall/index.htm
stuccoman is offline   Reply With Quote
Old 12-01-2006, 03:56 PM   #2
concretemasonry's Avatar
If you are considering using it for stucco, make sure it is approved by the local building officials.
Many municipalities are slow to accept anything other than the traditional three coat system (sometimes the modified two coat) over previously approved wall sheathing systems.
If you are in an area without the synthetic stucco and/or the very, very, very common faulty window installation problems, it may be easier to get approval.
The problems I see are automatically ignored by insurance companies if any substitutions are made. Municipalities requiring stucco inspections are very slow to allow substitutions.
concretemasonry is offline   Reply With Quote
Old 12-01-2006, 04:00 PM   #3
Thanks CCM
I am just curious if anyone has seen it being used. It says in the specs not to use it with stucco or Eifs. And it would still need another layer of moisture barrier to comply with ASTM.
Please do not get me started on improper window installation! Or lack of kickout diverters above gutters!
Old 12-01-2006, 04:52 PM   #4
Amen on the amateur contractor window installation!!!
Old 12-01-2006, 05:16 PM   #5
The bad thing is its the carpenters setting jobs up to fail long before any cladding is put on.
Old 12-02-2006, 12:40 PM   #6
I would guess that the new Huber product is similar to other acrylic permeable sheathing coatings like STO's Gold Coat and W R Grace's Perm-A-Barrier VP. These products are commonly used for commercial projects and are applied by spray or roller after sheathing installation and can seal mesh-reinforced joints and rough openings. I would be skeptical of the Huber taped joint approach.
mighty anvil is offline   Reply With Quote
Old 12-02-2006, 02:16 PM   #7
Anvil I have the same concerns!
Download Attachment: IMG_2346.JPG
121.97 KB
Download Attachment: IMG_2342.JPG
102.41 KB
Download Attachment: IMG_2343.JPG
114.4 KB
Download Attachment: IMG_2345.JPG
85.26 KB
Old 12-02-2006, 05:02 PM   #8
They have taken a liquid product that can avoid the problems associated with moisture behind homewraps and that can seamlessly seal joints and rough openings and they have reduced it to a system that depends entirely on tape. Another product dreamed up by a marketing department. The photos are frightening. I would put some building paper over it for cheap insurance.
Old 12-02-2006, 06:02 PM   #9
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by stuccoman View Post
Thanks CCM
As stuccoman pointed out, the manufacturer says DO NOT use this product with Stucco....
- Build Well -
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 04:28 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 02:11 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
