Water Proof Paper For PT Wood Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-15-2011, 03:35 PM   #1
Water proof paper for PT Wood deck
Last time I built a deck with PT wood, I was told to put that black tar paper between two pieces of wood that were in contact with each other. Now my lumber yard says the manufacturer of that paper has stopped because no one uses it and it is recommend NOT to use it. Your thoughts? Do I need the paper or will wood-on-wood do?
Deepaksji is offline   Reply With Quote
Old 06-15-2011, 05:13 PM   #2
kwikfishron's Avatar
Rewards Points: 998
Other than felt between the ledger and the wall I’ve never done that, seen that, or ever even heard of anyone doing what your describing.
kwikfishron is online now   Reply With Quote
Water Dripping from Upper Deck onto Patio JamuJoe Building & Construction 6 11-22-2010 10:51 AM
problem: Water on wood floor during refinishing HouseMgr Flooring 2 08-15-2009 09:19 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Not the usual TREX deck question... proper water drainage windowguy Building & Construction 2 06-28-2009 09:12 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
