Water Proof End Cuts Of Interior Dimensional Posts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-07-2012, 02:05 AM   #1
Water proof end cuts of interior dimensional posts
I have 4x4 and 4x6 posts that support a header over three 42" x 71" pane glass windows. They are exposed to the elements on the outside and are dry walled on the inside. The posts rest on a PT sill plate which sits directly on a slab. I'm about to replace the posts because the bottoms rotted - possibly due to moisture wicking through the sill plate. I plan to include a vapor/moisture barrier under the sill. In addition I want to seal the end cuts to ensure no moisture enters the post. I can't use the outdoor (green liquid which leaves a lingering odor) because of the smell. Any suggestions for a moisture and termite treatment for these semi-interior/exterior posts?
lakemans is offline   Reply With Quote
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 09:35 AM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 10:47 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
