| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Prevent Driveway Potholes
by eHow.com
No matter what type of driveway you have--concrete, asphalt or gravel--you are at risk for developing potholes. Potholes are caused by water penetrating the surface of the driveway. In the case of concrete and asphalt, the water builds up under the... Read More »
How to Maintain a Driveway
by eHow.com
With the popularity of garage-forward homes, the driveway is a focal point of many homes. It functions as a point of entry and can create curb appeal. Here's how to maintain your driveway to enhance your home's exterior beauty and avoid costly... Read More »
Raised Garden Beds: Install Drainage System 1
by Expert Village
We got our drainage for the, we're back over to the first tub we have our drainage up here ready to install it in the tub. If you notice I've reinforced the plastic flat with some cans and we're going to take them and put them over the drainage hole. The... Read More »
Raised Garden Beds: Install Drainage System 2
by Expert Village
Okay we are here at tub number 2 and we are finishing the drainage system with using PVC pipe. You will notice that I've only drilled holes on one side. The other side of the pipe is intact. We are going to roll the pipe over so that the holes are to the... Read More » Every engineering project needs to deal with the issue of drainage and water buildup. You need to calculate a variety of factors in determining drainage, including pipe size, building height and the location of municipal drains. It is important to use... Read More »
