Water Piple Attached To The Wall Loose - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-19-2007, 09:29 PM   #1
Water piple attached to the wall loose
I hope someone can help me here.
The waterline pipe that's inside the wall is pretty loose, I want to make it back to the way that it won't move, what type of stuff should I use?
cement? glue? or ?
One more quesiton, what type of cement or clay is it for the outside house wall here in CA?
707782 is offline   Reply With Quote
Old 10-19-2007, 09:58 PM   #2
ok, i know it's called stucco.
how do I get some extra stucco to match the color of my original stucco? By looking at it, i can't tell what color it is
Old 10-19-2007, 10:12 PM   #3
the roofing god's Avatar
Send a message via MSN to the roofing god
put pipe insulation on it,then use steel strip w/pre cut holes to secure arund the pipe insulation and secure to side of a stud(locate arond pipe right next to stud)----as far as the stucco,take a sample piece,compare it to the cement die colors,mix a preset amt of cement,start w/small amts of coloring until you match the color,keep exact recoerd of ratio as you add the die,you may need to redo as section as the wet will be darker as it dries unless you`re lucky and you can make tests and see how the color dries next to the pre-existing(do it on a board for comparison purposes)
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 10-19-2007, 10:13 PM   #4
the pipe should have a small amt of play for expansion/contraction
Old 10-19-2007, 10:18 PM   #5
Rewards Points: 5,336
You use a clamp to connect the water pipe to the wall. The metal of the clamp should be the same as the metal the pipe's made of. If the pipe is too far from the wall to attach, install blocking behind the pipe. Do you know what the pipe is made of?
Stucco is tinted with a powdered coloring when it's mixed, you won't duplicate that. Some stucco has been painted, that you might get close.
Ron
Old 10-19-2007, 10:25 PM   #6
The pipe is coming out the wall horizontally, those pipe straps would work if it's vertically.
Old 10-20-2007, 12:10 AM   #7
Long-Time DIYer
Mike Swearingen's Avatar
Is the "pipe" a water hose bibb?
If it is, the bibb should have a place for two screws on the sides. If it's coming out through stucco, you need to pre-drill the screw holes with a masonry bit, tap in lead screw plugs, and then screw the hose bibb to them. Any hardware store or big box should be able to give you what you need.
Mike
Mike Swearingen is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Wall Rot: Water, Mold and Ants xquercus General DIY Discussions 6 06-19-2007 09:55 PM
How to Space Water Heater Flue Vent from Outside Wall? austinbirdman Plumbing 1 03-12-2007 10:28 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
